Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 10th October 2008, 04:29 PM   #2031
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
The front has now 2 adjustable feet...
To baldly go where no man has gone before................(James Kirk)
Old 10th October 2008, 04:31 PM   #2032
I mounted the transport casing on to the ebony with 2 brass screws....
Old 10th October 2008, 04:32 PM   #2033
Already I have the benefit of adjusting....
Old 10th October 2008, 04:33 PM   #2034
....and again a "The PiTbull" is a little step further towards
my goal.....
Old 10th October 2008, 04:37 PM   #2035
kevinkr's Avatar
Way Cool Erik! Just wondering how many versions of this transport have you built so far? This will obviously be the best of the lot.. Quite a lot of effort, you must enjoy the challenge of it all. I have just the one of course, but I am quite happy with it. (Although my Sony SCD-777ES sacd player has once again assumed digital supremacy.. )
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th October 2008, 10:24 PM   #2036
I still use the same contraption which is electronic-wise ""finished""
...it gives me an enormous thrill and from scratch it plays 2-3 hours an evening ever since...
The idea is that when built it is/stays fully dismountable so we can mount all the electronics with transport afterwards when woodwork and copper is all finished....a bit more challenging to make I agree.....but that way you only build once....
The latest MUSICAL thrill gave me ....Horowitz....this thing is (for me in my set-up) as close to an analog rig as you can get......I have never ever heard him so full of colour as on my PiTbull.....
Forget the Weavers (yes I do have them) and check this out....STUNNING....hall...atmosphere...electricity ...topnotch play.......IN SPADES....
Old 10th October 2008, 11:43 PM   #2037
woodturner-fran is offline woodturner-fran  Ireland
Well i took some photos of my progress but after seeing the further steps that Erik has made mine will look pretty poor next door.....
Anyway, here goes:
Chassis - granite and alu with a damping layer of "glue":
Next showing the alu plate it will sit on within the whole box:
Then the chassis sitting on the plate. The springs are fairly stiff and definitely need to be damped a bit. The brass rods will keep the chassis in place if the shigaclone needs to be moved around:
Top view of the granite. I made up 2 support posts from alu and the mech can slip in and out if needed. Mech will be rigidly coupled to the posts:
And the front of the case for the shigaclone:
Sorry some of the pics aren't great, just didn't have time to set up lighting. i haven't done any mods to the mech yet except remove the inductor and the SMD caps on the back of the board. I think I have nearly all the caps now barring one or two and when I get the chassis sorted and playing I intend doing the standard mods. This will probably play into either a buffalo or else into Peters NOS DAC which hopefully will be on its way in the near future. I will put it up against my eastsound E5 to compare too....
Fran
Old 11th October 2008, 07:56 AM   #2038
Very inspiring pics...the spring suspension looks very promising and considering Peter''s experience it will already be a major upgrade...
Frontpanel looks unique and one of a kind...that is the fun of DIY!!
Keep those pics coming...nice.....
Old 11th October 2008, 10:52 PM   #2039
More progress!
(BTW, sorry about the blurry nature of some of the photos - shooting with no flash and 1/8" exposures not a happy combo)
So I finished the base plate for the transport within the case. Its held down with 12 M4 bolts and is very secure. It takes a lot of the ring out of the case too.
I experimented a bit with damping for the springs and ended up using some 1/2" pipe insulation cut to size. This fills the spring nicely, allows for the pillar and also takes a good bit of the "boing" out of the spring - which was something I was a bit concerned about.
Next up is another base plate, this time for under the case. There will be a layer of damping between it and the case. Heres the plate:
and with the M6 screws which will take the feet:
So taking a lead from the ceraballs but with a love of wood, I decided to make my own version. Here are the components, a machined pillar with grooves for some o-rings and a dimple in the bottom for a ball bearing. The top is tapped for the M6 screws mentioned earlier. The base is some ebony bored to take the pillar:
And assembled....
The idea is that the ball provides decoupling along with the bit of give in the o-rings. The pillar fits with a suction fit into the base.
Lastly tonight a rather poor pic of the feet in place under the base plate - they look better in real life. The M6 screws are held in the plate by some thread lock so the feet can be adjusted for levelling (about 4mm each foot)
I've decided to go BNC on this job. I've never used them before, but have some connectors. All my DACs use RCA, so I have made up a cable adaptor to suit. If i could just find my roll of damping I would be set!
Fran
Old 12th October 2008, 02:48 PM   #2040
alexg is offline alexg  Philippines
alexg's Avatar
Would the RC-EZ37V or the RC-EZ53H work?
These are just the two models that I can easily get in the Philippines.
Thanks.
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
