Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th March 2008, 05:50 PM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
When suspending mechanism from the bottom, using two spacers like this worked better than direct mount:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th March 2008, 05:56 PM   #12
kevinkr's Avatar
Tried Best Buy online, unfortunately they no longer carry this model.
I'll probably risk some low end units on eBay and see what I can come up with.
I found one I can buy for about $80 which is far more than I want to spend. Yeah I'm cheap..
www.kta-hifi.net
Old 27th March 2008, 06:02 PM   #13
Now, the clock. I tried Tent clock with a dedicated PS, but it didn't worked well. My findings has been quite similar what Romy says on his site:
http://www.goodsoundclub.com/Forums/...px?PostID=2171
I later installed Citizen 300-8441 crystal from DK and this is what I use till now:
www.audiosector.com
Old 27th March 2008, 06:05 PM   #14
steenoe is offline steenoe  Denmark
steenoe's Avatar
Ya must be kiddin' What is cheap?
Superb work Peter, as usual. The one that didnt work must have taken hours to make. Send it to me for proper disposal
Old 27th March 2008, 06:15 PM   #15
Beside all that, there are few components that I replaced on original board (replacing too many will kill the sonics).
I basicaly removed the main filter cap and replaced all other electrolytics tied directly to rails with BG N caps and also removed their SMD bypasses. One other cap was replaced to ERO 1830, 0.1uF and that's basically all. Okapi will post PDF when it's ready.
One other thing, the output resistors are quite important, I got the best results with Caddock MK132 75R to ground and VishayS102 60R (or similar value) in series.
www.audiosector.com
Old 27th March 2008, 06:25 PM   #16
luvdunhill's Avatar
any idea if and what flavor i2s might be available from the transport?
Old 27th March 2008, 06:32 PM   #17
I'm afraid the I2S output is not available. Here's the underside of PCB.
www.audiosector.com
Old 27th March 2008, 06:33 PM   #18
And this is mechanism in all its glory
www.audiosector.com
Old 27th March 2008, 06:50 PM   #19
luvdunhill's Avatar
what about pins 33-36 on the LC78620? I'm looking at the LC78620E datasheet, as I cannot make the exact number out from your photo. Looks to be i2s output.
Also, is the "B" designation important in the model?
Old 27th March 2008, 07:04 PM   #20
d to the g's Avatar
The first post doesn't mention the B, but the image of Peter's storage facility shows all B models. I'd like to know as well.
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
PASTICCI, blinkey, lucylu
Page generated in 0.14919 seconds (53.51% PHP - 46.49% MySQL) with 11 queries
