Finally, an affordable CD Transport: the Shigaclone story - Page 192 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd September 2008, 12:47 PM   #1911
okapi is offline okapi  United States
okapi's Avatar
Originally posted by Erik van Voorst
We tried the materials indeed and in a quick set-up we used it as a belt driving the clone and it works although if you go for it ...it will need a lot of perfecting....
did you use a 1:1 ratio for the drive and load pulley?
Old 3rd September 2008, 01:55 PM   #1912
Erik van Voorst's Avatar
Yes we took the trouble of taking a motor carefully apart and getting rid of the coils etc...and use it in its empty housing...
We mounted it (you have to buy 2 boomboxes...1 small tiny white wheel per machine ...hahahahaha) with a second motor this time one powered and with a little tension on the belt.....and GO
Obviously it was an experiment and although it worked it had loads of jitter....(a lot of difficulties to overcome....first spindle/platform/belt/second spindle ..it all has to be perfectly straight but it is NOT....etc etc)
I will not go as far as making a better spindle (couple of mm thicker) with ball bearings and oil etc etc....We reckon it most certainly will work but the mounting as I have planned will suffice more than enough for me...
I probably have still some photo's of this experiment at home..I will search...
To baldly go where no man has gone before................(James Kirk)
Old 4th September 2008, 10:08 AM   #1913
audio1st's Avatar
Hi Erik, have you tried tuning the PS.?Here
I know you like to experiment and you also have the ears for it
I'm sure it has made a difference to mine..
Old 4th September 2008, 03:40 PM   #1914
Audio1st, how do you create those nice images you always post ?
What value did you come up with for your ps?
I quickly tried some values, and it changes the sound for sure.
Old 4th September 2008, 04:17 PM   #1915
audio1st's Avatar
Hi rikkert1978,
I use Adobe Photoshop, the secret is adding "layer style", to bevel and emboss the lines.
I've used what I had handy so far, that was 1nF on a 50VA and 2.2nF on a 100VA transformer.. I hope someone with a better system and ears might find the "right" values?
Old 4th September 2008, 06:44 PM   #1916
brgds is offline brgds  Poland
Could you describe the character of these changes please, just to know what to concentrate on when listening?
Andy
Old 5th September 2008, 02:31 PM   #1917
No I have not although I do use the wimas in other positions..
Today I took some time to built the mock-up to get a good feel for sizing and design...
This way I know later on how to exactly use the expensive ebony/copper/acryl....etc.
The powersupply is imitated by the crosswood between the frontlegs..
The height is approx. 75 cm.
Old 5th September 2008, 02:32 PM   #1918
I made the stands already I used ebony...
Old 6th September 2008, 04:14 PM   #1919
Dan_ed is offline Dan_ed  United States
Erik, that is very cool and beautiful work, but you are a madman! I bet it sounds awesome. How much do you think the stand and player together will weigh?
Old 6th September 2008, 05:37 PM   #1920
Default Metal Source
Originally posted by Peter Daniel
[B]
The bars have been cut on table saw and smoothed out on belt sander, they are connected with 10-32 screws (two per each corner). The size is approx 7 x 7.5 x 1.25" There is 3/16 copper plate attached on a bottom and it holds the mechanism:
<SNIP>
Ok, I am over my summer model aircraft frenzy and ready to build my Shigaclone. I want to do a Peter Daniels-style bronze/copper frame and am looking at metal sources. So far I'm looking at OnlineMetals.com. Any other sources worth seeing before I place an order?
Also, for another project, anyone know of a good online source for Corian sheets?
TIA!
Greg in Mississippi
Everything matters!
Copyright 1999-2017 diyAudio
