Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 20th August 2008, 01:06 PM   #1831
chakija is offline chakija  Serbia
chakija's Avatar
Heh , i got this DAC for free ,from a friend on local forum .
He tried many mods on it and finally got bored and decided to give it someone as a gift.
Well ,maybe i was to rough calling it waste of time ,but that's just opinion of him ,and few others that tried this DAC.
After op amp change (BB2111) ,battery supply ,trafo's on interstage he concluded that it beats some 700-800e dac's.
Unmoded he said it sound just like ordinary player like mine.
However ,i have not heard it yet ,but i surely will and with shigaraki too.
I truly hope that this combo will beat my sony x222es ,which is nothing more than an "portly" player but still doing it's job.
Btw. price-quality combo is really unbeatable (especially in my case )
Puffin ,do you have this dac 2 ?Have u menage to connect it to shigaclone ?
Old 20th August 2008, 05:53 PM   #1832
Puffin is offline Puffin  United Kingdom
Oh yes. Running in balanced mode with AD Op-Amp and modded to accept 96Khz with up-sampler. Sweet!
Old 20th August 2008, 07:01 PM   #1833
chakija's Avatar
That's great !
Did u connect it through optical link ?Could u post some pictures and some quick step by step guide of things u did in newb terminology .
Thanks in advance
Old 20th August 2008, 07:31 PM   #1834
jonners is offline jonners  United Kingdom
jonners's Avatar
Default Cheap Chinese dac
This dac has a couple of threads of its own here: See http://www.diyaudio.com/forums/showt...5&pagenumber=1
and http://www.diyaudio.com/forums/showt...hreadid=126789
Also, on another forum: http://theartofsound.net/forum/showthread.php?t=315
John
Old 20th August 2008, 08:55 PM   #1835
dantwomey is offline dantwomey  Canada
Default Re: Cheap Chinese dac
John
A free plug for Peter here. Not that he needs one. I have his TDA1543 NOS DAC, which comes as a kit, and I found it exceptional.
Dan
Old 21st August 2008, 06:24 PM   #1836
rubydac is offline rubydac  Hong Kong
Send a message via MSN to rubydac
Question Do JVC RC-EZ38 you for Shigaclone ?
I can't find 31 and 51 in ASIA, but if I can find sanyo module which model can support ?
Rubydac
Old 21st August 2008, 10:04 PM   #1837
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Default Re: Do JVC RC-EZ38 you for Shigaclone ?
Originally posted by Pocoyo
This is the laser parts and motor
for replacement your CD if they
had trouble someday
Place order in
http://www.diyaudio.com/forums/showt...61#post1589861
Rubydac
http://www.sanace.com/Optical_Lens/SF-P101N.html
No pcb
CanĀ“t help any further
JC
Old 22nd August 2008, 02:00 PM   #1838
rikkert1978 is offline rikkert1978  Netherlands
Mmm I made a new power supply, and also installed a crystal oscillator, now it wont read the TOC properly...
I reinstalled my TentClock, and same thing here. The only difference is the lenght of the clock feed supply; I cut those wires and attached the crystal to it.
With only the crystal attached, (no Capacitors) it didnt work at all; he never read the toc.
Any tips on how to make the crystal work with the 3 wire trick perhaps? I`m not sure how to hook it up ;-)
O CRYSTAL
OOO + - + at the printboard
! < 3 twisted wires not connected at the end
Old 22nd August 2008, 02:35 PM   #1839
kevinkr's Avatar
The crystal is soldered to the outer holes, the center hole is ground and is not used with the crystal. (The resonator had internal caps connected to this point.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd August 2008, 03:08 PM   #1840
Predator864 is offline Predator864  Europe
Guys, found some interesting DACs:
http://www.diyaudio.com/forums/showt...24#post1585824
or
http://www.analogmetric.com/store/goods.php?id=195
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
