Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 15th August 2008, 08:15 PM   #1761
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
today I finished the dismounting of the motor...
It is loose from the board and the board is now supported by an ebbony wall...
1,4 mm (washer) under the board...
To baldly go where no man has gone before................(James Kirk)
Old 15th August 2008, 08:16 PM   #1762
The wall can be fully adjustable as the motor...
Old 15th August 2008, 09:23 PM   #1763
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Default Re: CD Clamp
Originally posted by Pocoyo
Is Okapi selling his clamp Now ?
Regards, Jeffry
Search Clearaudio (Roy) in this thread, if you wish.
Cheers
JC
Old 15th August 2008, 09:46 PM   #1764
jims is offline jims  United States
I agree with Kevin stick to the magnetic puck, at least until something better comes along. I have been trying to stop mine from wobbling, using Peter's method, for the past 2 days. It is not much better. I am taking mine to a machine shop on monday to see if they have any ideas.
JimS
Old 16th August 2008, 04:06 PM   #1765
kevinkr's Avatar
JimS
Mine had wobble in two planes and while I could have shaved the platter to get rid of the vertical wobble, the eccentricity in the horizontal plane would have remained. My mechanism could not even read the tocs with the original or much improved clamp mechanism.
Loading and unloading cds was really difficult as well, getting the clamp tight was hard, and getting it loose afterwards was if anything even more difficult..
It looked cool, but the idea is not such a hot one unfortunately. A small weight based set up like that used in some high end Sonys would work better at the possible risk of knackering the lower motor bearing.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th August 2008, 10:45 PM   #1766
...today I picked up clamp no. 1000
I definately want to get rid off the magnet so I am willing to go thru Hell....and believe me I am....this time from a pro shop...made out of a big chunk of acryl....
Anyway this one seems to be the best so far..it gives a rather good alignment..
At the same time I kind-off over engineerd a brake system so I won't have to touch the cd's while handling the puck....you do not want that a very uncomfortable job...
Old 16th August 2008, 10:47 PM   #1767
I pressed it home with a drillchuck....using its wheel and some helpfull handmade tools..( wooden clamp en a wooden platform with holes to support the bottom of the motor as "stressfree" as possible........
for me 2.5 mm space from the bearing does the job
(1 mm standard and 1.5 mm for detachment)
Old 16th August 2008, 10:48 PM   #1768
I got the measurements right so ready for mounting in his own copper clamp...
Old 16th August 2008, 10:49 PM   #1769
In place but still adjustable with 2 side screws....just in case..
Old 16th August 2008, 10:52 PM   #1770
And the brake/hold-in-place system......so I do not have to touch my cd's'.....
A daytime job but it works although I am going to refine it a bit...
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
