Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 14th August 2008, 01:15 PM   #1741
JeroenR is offline JeroenR  Netherlands
top view.
Old 14th August 2008, 01:50 PM   #1742
kevinkr's Avatar
Originally posted by JeroenR
top view.
Very nice!
The suggested divider is for spdif over coax, you drive a totx directly as you are doing.
FWIW toslink optical is inferior - your shigaclone really deserves the best bnc/coax set up you can manage. Make your other devices compatible with it, not the other way around and you will have no regrets.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th August 2008, 02:24 PM   #1743
Originally posted by kevinkr
Very nice!
Thanks!! Showing off one's concoctions is part of the fun I guess.
Aha, so I need a switch before the divider then. Thanks.
My other project is a pcm1794 (Twisted Pear) with RAKK tube output. I want to feed that from my Airport Express so I need a toslink anyway on the DAC (next to a BNC of course). Having a toslink on the transport would then be just for convenience.
And... for now I have a single TDA1543 DAC with only toslink to test.
Jeroen.
Old 14th August 2008, 03:01 PM   #1744
kevinkr's Avatar
Jeroen.
Get rid of the toslink on your tda1543 dac and I expect you will notice some significant improvement. The receiver IC should accept spdif levels without a problem or you can google for a simple spdif receiver..
Old 14th August 2008, 04:16 PM   #1745
The receiver in the TDA1543 DAC is a cs8416 Twisted Pear board that has a transformer spdif input so I could try that (it is hidden under the DAC print). Again, I do want to be able to use the Airport Express sometimes (music and movies). I'm a bit stuck though on how to switch between BNC and toslink without compromising the BNC quality.
Thanks for the input Kevin!!!
Jeroen
Old 14th August 2008, 04:24 PM   #1746
kevinkr's Avatar
Jeroen
It might take some improvisation but it would probably be a good idea to convert the airport express to spdif as well. Use a good spdif transformer for isolation, and I would recommend adding a cm choke ahead of the transformer. Take a look at my old media server thread for some details on cm choke/transformer combo.. Does your CS8416 board have an option for not using the transformer? It doesn't seem to be necessary with the Shigaclone (I'm not using one in my clone or dac) according to Peter as well, and with the suggested mods you don't need it with the airport either. (Note that my current sound card does have a transformer, but the output is not isolated from the computer chassis as far as I know. (Haven't checked) Sounds fine going through two transformers though (and in a lot of pro and very high end gear this would also be the case.)
Old 14th August 2008, 04:45 PM   #1747
Predator864 is offline Predator864  Europe
I bought one unit. I will have it in aprox. 10 days.
Price: ~ 40 Euros.
Hope I`ll be pleased
Can somebody give me some chassis drawings ?
Old 14th August 2008, 07:07 PM   #1748
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
I made a start by trying to dismount the motor from the laser sled and mount it 1 mm underneath that platform ...the motor this time mounted to the thick copper enclosure....
To baldly go where no man has gone before................(James Kirk)
Old 14th August 2008, 07:08 PM   #1749
I use a dummy spindle motor and a dummy platform to fool around with...
Old 14th August 2008, 07:10 PM   #1750
My aluminium laser platform will be detached like I try to point out here....
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
