Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 3rd August 2008, 05:26 PM   #1621
jonners is offline jonners  United Kingdom
jonners's Avatar
I tried again with the 5V supply, this time connecting it to point 5A on the pdf. I cut the trace that goes between that point and the cap near to the inductor. But still no luck - the disc continued to spin without reading the TOC.
On wiring 5A to 5B and reverting to just the 8V supply normal operation returned.
What am I doing wrong - any ideas?
Old 3rd August 2008, 05:30 PM   #1622
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Suggested a while back, but there are reset lines in the driver chip that my need the transistor in the regulator circuit in order to function correctly. If you have a scope, you might look at those two lines to see if they behave the same with the differing power situations.
Pins 16 and 17 on the LA6541.
Old 3rd August 2008, 06:18 PM   #1623
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally posted by jonners
Hi Richard
I got my caps from Parts Connexion. Filling in their order form was a bit tedious but delivery was extremely fast.
Don't think you've missed anything.
John
Thanks John
I was going to try ordering through Percy Audio (not sure how speedy their service is) and get the remaining parts from Peter.
I am new to electronics, so can you answer this? If a suggested capacitor is for example 4.7/50v, will a 4.7/100v be OK as a substitute? I am assuming the voltage is a maximum and does not affect the sound.
Richard
Old 3rd August 2008, 06:26 PM   #1624
kevinkr's Avatar
In general substituting higher voltage caps is ok, however physically they may not fit the available space. (In the old days it was recommended that much higher voltage rated caps than called for in a particular application not be used due to deterioration in the dielectric at lower than design voltages, causing a reduction in capacitance, etc.. - this no longer appears to be a problem with modern caps, and today generally the higher voltage rated parts have better DA/DF performance than comparable lower voltage parts.)
I have been dealing with Michael Percy for over 20yrs now and he is both prompt and reliable.
On an unrelated topic make sure that the platter and clamp assembly on your 'clone runs flat and true as the increase servo activity if this is not the case seems to ruin the sound. I have one platter that is nearly perfectly flat and one that isn't and I thought I could hear a definite difference. Should yours not run true find one off of an old laptop cdrom drive as discussed earlier in the thread.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 3rd August 2008, 06:41 PM   #1625
Tripmaster's Avatar
Thanks Kevin for the information. You might know this, The cap is the 4.7/50v. Will the 100v cap fit in it location? There is only 3mm in it so I guess it will. The legs should also be the same distance apart
Richard
Old 3rd August 2008, 07:06 PM   #1626
jonners's Avatar
I remember seeing your idea and I left the transistor in the regulator circuit, so that should still be functioning. Thanks for your suggestion, though. I don't have a scope but I will see if I can find a way of understanding what's going on.
Old 3rd August 2008, 07:46 PM   #1627
dantwomey is offline dantwomey  Canada
Perhaps this is why Peter cut the trace and fed +5v from C916 on. Leaving the transistor in place may serve some function I'm overlooking.
Dan
Old 3rd August 2008, 09:22 PM   #1628
Tripmaster's Avatar
Originally posted by johnm
Finally finished with the electronics side of the Shigaclone now - at last!
VERY happy indeed with it - certainly the best sound from red-book CD I have heard to date... and its still sitting bare on an upturned mouse mat haha! Will be experimenting with bamboo chopping boards next!
Altered my DPA DAC to BNC inputs this afternoon, and changed the output on my Shigaclone to BNC also. Also changed the output resistors to 392 /93 ohms yesterday. I'm amazed at the change - punchy bass which you can sometimes feel rather than hear. Nice 'bouncy' bass guitar rendition which one is able to follow, rather than having it submerged as in lesser players. All the sound quality of the stock JVC now, but with added punch, detail, and refinement (but NOT at the expense of speed or an exciting sound). Love it! Have to say though I also had more or less the same quality from using that resistor output with regular phono sockets as well. Adding the BNC's didn't seem to improve anything, at least not that its really noticeable - perhaps a little extra clarity but hard to tell.
I have to say that I am currently not missing my Garrard 401 rig at all, which is saying something!
Incase nobody can be bothered to read through the posts, here's a summary of what I changed:
C934 - 4.7uF Black Gate N
C929 - 4.7uF Black Gate N
C953 - 47uF Black Gate N
C906 - Keep the original in place!!!
C916 - 47uF Black Gate N
C939 - 47uF Black Gate N
C952 - 470uF Elna Silmic ARS
X901 - Citizen CSA-309
Remove - refer to Okapi's PDF file.
Digital output - 75-ohm BNC. 392 ohms series, 93 ohms shunt.
- John
Hi John
I think it pays to read a few more posts prior to asking unnecessary questions!
Richard
Old 4th August 2008, 12:28 AM   #1629
Zigis is offline Zigis  Latvia
Citizen 300-8441 crystal frequency is 16.9344Mhz, I can find locally only quartz 16.0000Mhz.
Can it work ?
Zigis.
Old 4th August 2008, 12:40 AM   #1630
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Can it work ?
Zigis.
nope .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
