Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 2nd August 2008, 08:52 PM   #1601
dantwomey is offline dantwomey  Canada
Originally posted by jonners
I just want to report that I tried this method of connecting a separate 5V supply but couldn't get it to work. The disc would spin for a while but when it stopped the display showed zero and the disc wouldn't play.
I've been looking at this and have some questions.
First we can see where L901 is removed to supply our 8vdc. To supply a separate 5v we have to remove Q902 and supply +5vdc to the opening left by the collector or to the + side of C916.
The negative sides of the +8 and +5 supplies would have to be reference (tied) together and be powered up at the same time?
I was wondering if we could tap into Peter's original supply just after the diodes and regulate down to a +5v supply from there?
Dan
Old 2nd August 2008, 09:21 PM   #1602
jonners is offline jonners  United Kingdom
jonners's Avatar
Dan
Hello Dan
Yes, you can certainly tap the supply after the diodes to supply a 5V regulator.
The 8V and 5V supplies would then be sharing a common earth so you would only need one earth connection to the board.
However, as I said - I can't get this to work! This was, I believe, a suggestion that Peter made which he hadn't actually tried. The method he used was to cut the trace leading from the collector and connect the 5V there, but this looks difficult to me - I think the trace that needs to be cut is under the heatsink.
John
Old 2nd August 2008, 09:28 PM   #1603
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
Today I nearly finished the external power supply box and I worked on the transport lower deck...a nice damping bottom for the trafo's
To baldly go where no man has gone before................(James Kirk)
Old 2nd August 2008, 09:29 PM   #1604
The piTbull logo is temporarily attached with two sided adhesive tape for a try out....
Old 2nd August 2008, 09:30 PM   #1605
Hello Dan
However, as I said - I can't get this to work! This was, I believe, a suggestion that Peter made which he hadn't actually tried. The method he used was to cut the trace leading from the collector and connect the 5V there, but this looks difficult to me - that trace that needs to be cut seems to disappear under the heatsink.
John
I'm missing why the trace would need to be cut. Couldn't we not use the collector pad from the removed Q902 as the location for the +5v wire? This leads to C916 which feeds the +5v to the require areas?
Dan
Old 2nd August 2008, 09:32 PM   #1606
The lower deck is now firmly supported by four massive copper tubes with approx. 6 mm wallthickness...and high enough to mount electronic boards such as regulators and a clock...
Old 2nd August 2008, 09:36 PM   #1607
jonners's Avatar
Dan
I believe Peter left Q902 in place, and cut the trace instead of removing it.
John
Old 2nd August 2008, 09:55 PM   #1608
kanifee is offline kanifee  United Kingdom
erik how did you aquire such industrial size pieces of copper, they seem so rare these days, the plate and tubing is of measurements beyond the normal end user market. your design seems to stear quite far away from your organelle mock up, where are you taking this design?
Old 2nd August 2008, 10:34 PM   #1609
John
Yes. The jumper wire listed in playermods.pdf goes to the + side of C916. You could just cut the trace and feed your +5v there.
Dan
Old 2nd August 2008, 11:23 PM   #1610
jonners's Avatar
Dan
Yes, I think you're right Dan. But the schematic doesn't entirely agree with what's on the board. (Erik did refer to mistakes). The schematic shows the +side of C954 connecting only to the LA6541 chip. On the board it connects with the 5V+ at C916! (Mind you, I do have the EZ51 not the 31 - but all the component numbering etc. looks the same to me.)
John
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
