Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 25th July 2008, 08:29 PM   #1491
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
Originally posted by brgds
Thanks. Final check: if I leave existing 8V regulator, and add a new super 5V, all to do is to remove Q902 and supply it's output pad. As the result crucial circuits are supplied with 5V excelent regulator, and only less critical motors' driver with lower quality 8V, and the noises from motors' supply do not influence 5V supply, right?
Yes, but what is excellent and what lower quality is still to be determined
I did not remove Q902, only cut traces, but don't see a reason why removal shouldn't work.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th July 2008, 09:39 PM   #1492
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Originally posted by JC Fardo
Trying to complete Andy´s question:
Are this regs a good choice
No, low quality opamp is used as error amplifier so performance is no better.
Non é mai abbastanza...
Old 25th July 2008, 11:30 PM   #1493
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
JC
Old 26th July 2008, 10:02 AM   #1494
Puffin is offline Puffin  United Kingdom
I have built a flea supply for the 16.93 crystal that I obtained from Peter Daniel. I have tried to connect it up as in the schematic attached. However the transport is reading the disc and making music even if the flea is turned off. I am also getting a loud buzzing noise.
I assume that I have either got the orientation of the crystal wrong, or that I have to cut the power supply to the point where the crystal was originally attached?
I have attached the crystal as to one leg to the +5v and the other leg to one point on the board. The ground wire from the flea is attached to the other point for the original connection.
http://www.acoustica.org.uk/t/naim/35clockreg.html
Old 26th July 2008, 12:12 PM   #1495
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Hello Puffin,
Remove original crystal and connect new clock as below...
Old 26th July 2008, 12:27 PM   #1496
jonners is online now jonners  United Kingdom
jonners's Avatar
Puffin
Are you using the crystal in an external clock circuit - such as this one: http://home.quicknet.nl/qn/prive/ra....s/CD_clock.pdf ? If so, then it will work as Audio1st has just shown. But it won't work with an external supply if you have just got the crystal connected directly to the board.
Old 26th July 2008, 12:48 PM   #1497
jonners& Audio1st. Thanks for your replies. I am finding my way here so forgive me if I may not understand. The flea is a regulator to which I have attached the crystal oscillator. The flea is shown in the document I attached previously with a Tent Clock (16.93) attached. It can be used for other applications. I don't know if what I have made would be classed as an external clock circuit or just an external power supply with crystal attached.
I'll post some pics later if it will help.
Old 26th July 2008, 01:30 PM   #1498
Hope this helps
Old 26th July 2008, 01:41 PM   #1499
Old 26th July 2008, 01:57 PM   #1500
dantwomey is offline dantwomey  Canada
Originally posted by jonners
Puffin
You have me puzzled here. I'm building a separate clock (KC7) with it's own independent PS.
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
