Finally, an affordable CD Transport: the Shigaclone story - Page 149 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th July 2008, 08:13 PM   #1481
Erik van Voorst's Avatar
I must say that because of an incorrect electrical -31 scheme it is rather difficult....I received help.
In short it is determining where you pick up the proper trace of the chips.
I think nothing for a newbee....sorry...
To baldly go where no man has gone before................(James Kirk)
Old 25th July 2008, 08:35 AM   #1482
quan is offline quan  Australia
Hi , i just wonder any one else have tried seperate super-reg as per James post 1269-and the final result compare to just LM7808 as the pre-regulator.
Old 25th July 2008, 09:34 AM   #1483
jonners is offline jonners  United Kingdom
jonners's Avatar
Originally posted by dantwomey
The ALWSR replaces the LM7808 shown on the diagram on the first page of this thread.
The shortcoming of that is that you won't get the full advantage of the ALSWR because the supply is still going through the internal 5V regulator in the LA6541 chip. (That's according to the schematic -which Erik says is incorrect. Post 1269 refers to MM1469. The chip is under the heatsink so the number is not visible.)
Old 25th July 2008, 11:31 AM   #1484
brgds is offline brgds  Poland
Guys,
could you advise in details how to deal with these additional regulator (I'm not newbee ) , please?
Andy
Old 25th July 2008, 12:53 PM   #1485
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Referring to page 16 of service manual: http://www.ferdsaudio.com/RC-EZ31.pdf
8V is connected right after choke L901 (the choke is recommended to be removed).
There is also 5V supply, based on Q902. If you want to use one super regulator you should probably start with 5V supply; in that case remove transistor Q902 and connect 5V wire from regulator to collector pad, the ground from regulator connects to negative pin of C916. You can also cut the trace from collector output (Q902) and connect external 5V there (that's why you see black wire jumper in some of my pics).
You may also consider 8V super regulator and this would connect right after choke (L901)
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th July 2008, 02:30 PM   #1486
Peter,
thanks, I didn’t realize it’s so simple…
Does it mean that if I put 5V regulator then 8V is not needed at all?
Andy
Old 25th July 2008, 02:35 PM   #1487
8V regulator is required for motors, you may notice that LA6541 is powered by both 8V and 5V.
www.audiosector.com
Old 25th July 2008, 02:37 PM   #1488
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Need to also watch the reset function on the LA6541 chip, pins 16 and 17. They appear to be driven through the in chip regulator and the data sheet is not too clear on how they work.
Old 25th July 2008, 06:41 PM   #1489
Thanks. Final check: if I leave existing 8V regulator, and add a new super 5V, all to do is to remove Q902 and supply it's output pad. As the result crucial circuits are supplied with 5V excelent regulator, and only less critical motors' driver with lower quality 8V, and the noises from motors' supply do not influence 5V supply, right?
Andy
Old 25th July 2008, 07:29 PM   #1490
JC Fardo's Avatar
Trying to complete Andy´s question:
Are this regs a good choice
http://www.audioupgrades.co.uk/regs.shtml
JC
Copyright ©1999-2017 diyAudio
