Finally, an affordable CD Transport: the Shigaclone story - Page 144 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th July 2008, 01:53 AM   #1431
quan is offline quan  Australia
Yeah , i got one from Elso-great value for money ,and with dedicated PSU-sounds great on marantz 63SE.
Iam currently using a Bursonaudio clock with PSU with Shigaclone
Old 20th July 2008, 10:53 AM   #1432
kanifee is offline kanifee  United Kingdom
Back to pick your brains, im going to try and breadboard the psu for this cd transport, its pretty essential i think that if im going to progress anywhere in this hobby breadboarding is a must and ill be able to experiment a lot more, i also think it will reassure me i know the schismatics if i know i can breadboard them up.
IT may be spot on and i just need reasuring from a more experienced mind or i may be horribly wrong and are saving my self from certain doom but if i were to point tp point the psu is this correct?
Basic stuff i know but better safe than sorry!
Old 20th July 2008, 11:15 AM   #1433
jonners is online now jonners  United Kingdom
jonners's Avatar
kanifee -
Your picture shows +12V and-12V input, but if those wires are coming direct from the transformer, as they should be, it's actually 12-0-12V AC.
Your earth wire goes to the centre tap of the 12-0-12V transformer, right?
John
Old 20th July 2008, 11:19 AM   #1434
i dont actually posses the trany yet, im buying that the week coming but yes that would go to the center tap, to be honest im unsure about trany types as well so im still looking into that the only trany ive used had dual secondarys and 4 wires coming from the trany, ac1,ac1 and ac2,ac2 though im making an educated gues that both lives go to 12v and the earth goes to the 0 line. im unsure about 3 wire tranys though i have seen people using some with 2 wires joined, any info on this? and does the pic look correct aslong as all wires go to correct points on the trany?
EDIT layout of the pic and the lines was more to do with keeping it less jumbled though i did realise why the origanel had the wires laid out 12 ground 12 instead of 12 12 ground like me
Old 20th July 2008, 11:22 AM   #1435
Erik van Voorst's Avatar
Today I made a switch mount...
To baldly go where no man has gone before................(James Kirk)
Old 20th July 2008, 11:24 AM   #1436
....and in place in this case first on a " dummy "....
Old 20th July 2008, 11:29 AM   #1437
jonners's Avatar
kanifee-
With dual secondaries you create a centre tapped winding by joining the end of the ac1 winding to the beginning of the ac2. Check with a meter before going any further.
John
Old 20th July 2008, 11:32 AM   #1438
so that component orientation and layout and wiring looks ok?
Old 20th July 2008, 11:40 AM   #1439
Clock works okay now I had a brainfog but Anton solved it...
Old 20th July 2008, 12:30 PM   #1440
jonners's Avatar
Yes - though I can't quite see the orientation of the caps. Earth leads -ve of course.
Copyright 1999-2017 diyAudio
