Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 19th July 2008, 04:23 PM   #1421
jonners is offline jonners  United Kingdom
jonners's Avatar
Thanks Peter - I hadn't got it quite right, glad I checked here first!
Old 19th July 2008, 04:38 PM   #1422
kanifee is offline kanifee  United Kingdom
What sort of impact if any does clock freaquancys have on the final product and is the frequency open to experiment or is it best to stick to a certain frequency?
Old 19th July 2008, 04:40 PM   #1423
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
You need to use the exact frequency, the transport will not work with any other
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 19th July 2008, 05:27 PM   #1424
jonners's Avatar
Now spinning with Trichord Clock in place. First impressions are very favourable.
Old 19th July 2008, 06:20 PM   #1425
jonners's Avatar
After a bit more listening with Trichord clock I'm agreeing with Erik - more body to instruments, more 'live 'feeling. I think it will stay.
Old 19th July 2008, 06:57 PM   #1426
dantwomey is offline dantwomey  Canada
I've emailed Elso. I may try a Kwak Clock.
Dan
Old 19th July 2008, 09:55 PM   #1427
looser101 is offline looser101  Canada
Originally posted by Erik van Voorst
Okay no problem...I can always put a switch on a homemade breadboard attached to the motors...or a cleaned spare board....
I was realy interested in the easy way to determine its exact location by only attaching it to the motors.....
How about this Erik?
SANYO
Old 19th July 2008, 11:45 PM   #1428
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
Thanks but I have a good option...for the switch...
Peter thanks for your advice on the clock grounding...I think that loosing my lock ever so often with the Genesis Digital Lens
(once every couple of tracks) for a few seconds might be due to the fact that I picked up ground at my 8Volt regulator....any suggestions for that problem....I was not sure how exactly you mounted the tent...being a different clock ....
I will try your suggestions maybe it gives me a more stable mariage with the Lens (which can be quite finnecky)....
Good to hear that the Trichord is bringing something for more people...I hope the Kwak clock also delivers because it is always a gamble if it sounds really better........
To baldly go where no man has gone before................(James Kirk)
Old 19th July 2008, 11:57 PM   #1429
Id give the kwak clock a go though being a relative noob to this im not to confidant making breadboard rigs, not entirely sure i understand schismatics fully yet or at least translating them to pcb set up.
Old 20th July 2008, 01:18 AM   #1430
In the past Elso has sold clock kits c/w parts and PCB. I put one in my CD67SE about two years ago.
Dan
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
