Finally, an affordable CD Transport: the Shigaclone story - Page 140 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th July 2008, 11:23 AM   #1391
JC Fardo's Avatar
Originally posted by jonners
Current state of play - mounted rigidly on granite. (audio1st showed the way, IIRC )
The granite is quite 'ringy', so will need to be damped somehow, perhaps by attaching bitumen pads to the back.
And then..... the flashing blue lights!
Hello Jonners
Inspired also by audio1st Im im progress building same structure and planning to bond the granite base to 9mm mdf underneath using 2 components stone compound adesive. Any thoughs?
Cheers and thanks
JC
JC
Old 17th July 2008, 12:46 PM   #1392
audio1st's Avatar
Default EZ31b in UK.
"ASDA" in Milton Keynes still has the EZ31b at 25.
Old 17th July 2008, 12:50 PM   #1393
jonners is offline jonners  United Kingdom
jonners's Avatar
Originally posted by JC Fardo
Hello Jonners
Cheers and thanks
JC
Hello Jose
Sounds like a good plan, except for the fact that it's not exactly reversible if you don't like the result!
Cheers, John
Old 17th July 2008, 01:10 PM   #1394
luvdunhill's Avatar
Originally posted by Zen Mod
I've heard these blue lights work best
http://technology.newscientist.com/c...ine-news_rss20
For Sale: Yet-Another-FirstWatt-PSU | "CSX1/2" "Buffered F6" FE
Old 17th July 2008, 01:58 PM   #1395
Dan_ed is offline Dan_ed  United States
Ha! I saw that news article just a few days after attending a Rush concert complete with green lasers. I had to read it to make sure it wasn't me.
Hopefully, my transports will be arriving soon so I can get started on this project. I've ordered a Chime DAC kit from Jim Hagermann so I'm expecting great things from my new digital sources. I'm not sure how I'll mount the transport and the DAC so they'll probably live on some plywood for a little while.
Old 17th July 2008, 04:12 PM   #1396
Erik van Voorst's Avatar
Today I did built a 5 Volt regulator
(my super reg is still not in the mail )
So I can fool around with that.......
I also made a toc-switch (the wooden peg is becoming quite a hinderness when you play dozens of cd's) and a switch to get the cd illuminating blue-led on/off....
When I switch (being not in the optimal listening position) on/off my impression is that I can hear NO difference...sorry to say (so far )...
However I will investigate further...experimenting with the intensity and the led- position.
I will also kindly ask my wife to switch
(the toggle that is )
To baldly go where no man has gone before................(James Kirk)
Old 17th July 2008, 04:34 PM   #1397
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
This might be a stupid question, havent followed the issue closely, but has anybody used hall-effect switch for TOC switch ?
That way all we would need to do is use the metalic layer of CD to switch TOC reading.
Old 17th July 2008, 05:14 PM   #1398
kevinkr's Avatar
Interesting idea, unfortunately IIRC the metalization is non magnetic so I suspect a hall effect switch would not work.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th July 2008, 05:21 PM   #1399
BoilermakerFan's Avatar
Does the switch have to be latched/maintained or can it be momentary? I know on the actual player it was maintained by the cover.
- BMF
Old 17th July 2008, 05:27 PM   #1400
kevinkr's Avatar
- BMF
It must be remain in the closed position in order to play the cd.. Opening immediately aborts play and deletes the toc contents in the microcontroller memory, closing initiates a new toc read.
Copyright 1999-2017 diyAudio
