Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 15th July 2008, 12:05 AM   #1341
Pendergast is offline Pendergast  Canada
Originally posted by Dan_ed
Pendergast,
Isn't there a relay that needs to be closed? I think that is the one Erik van Voorst made a long stick to close it with. You can try closing it with your finger and see if that gets the motor spinning.
Thanks Dantwomey!
Dan
And where would that be?
Old 15th July 2008, 03:09 AM   #1342
kevinkr's Avatar
No relay, but there is a limit switch right by the capacitors and adjacent to the motor. The bottom of the sled has a "feature" which hits the switch at end of travel. I have a hard time believing that it will not spin up unless that switch is open. (Mine immediately parks in such an instance.) How about the door switch? Loose connection? Something else going on?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 15th July 2008, 03:29 AM   #1343
dantwomey is offline dantwomey  Canada
I'd like to join the long list of people thanking PD for sharing this little gem with us. The Shigaclone has raised the bar in my system as high as it's ever been. I'm thoroughly enjoying going through my CD collection again.
Dan
Old 15th July 2008, 07:42 AM   #1344
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
Hi I saw you foto's of your own CD-Bunker very cool
I WOULD DEFINATELY TEST YOUR SUSPENSION BY EAR IN THAT BOX SOFT OR HARD....to fully enjoy all your box-work
About your motor...that must be something simple...eg maybe one of the wires not proper connected or broke ...did you check the voltage before attaching the motor to the wires...
Maybe try a spare boombox (for your stock laser) and fool around with that....I find that very beneficial for solving problems......
To baldly go where no man has gone before................(James Kirk)
Old 15th July 2008, 07:58 AM   #1345
MrMajestic is offline MrMajestic  Sweden
MrMajestic's Avatar
I have one EZ31 unit dismounted that Im not going to use if anyone is interested.
Old 15th July 2008, 12:33 PM   #1346
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default Dont forget me Okapi
Hiii Okapi pls join me to your GB
I need that thing 2 pcs ( plastic disk ? )
pls give me confirm
thanks before Okapi
Old 15th July 2008, 01:52 PM   #1347
clearaudio is offline clearaudio  Singapore
Default Re: Interested Check
Originally posted by clearaudio
For all of you whose interested in the platter and screw on cap for the shigaclone mechanism, I am able to supply. The cost is USD$50 including postage to any where in the world. it will be made either in delrin or nylon. Pictures to follow soon. PM me, from Singapore.
Long overdue! Here are the Delrin platter and screw cap top I was talking about. Please email me if you want them.
Old 15th July 2008, 02:21 PM   #1348
Clearaudio I have e-mailed you
Today I spend a few hours experimenting with MDF to start
building a prototype a-la Kalista Metronome...
This way I get familiar with problems so later on I can proceed with copper etc...
Old 15th July 2008, 02:23 PM   #1349
I have built a 4 mm topplate and cut out the laser and platform-hole...
Old 15th July 2008, 02:23 PM   #1350
flodge is offline flodge  United Kingdom
Question no digital out
Hello everybody
My first post in this thread so I hope that you will excuse me for taking your experiences and silently, if imperfectly implementing them. But now I have hit a snag. I have built a reasonable attractive transport out of oak and ali. It spins up,I can control it, it will output through it's own dac ( pretty bad sounding ) but seems to have no output at spdif. Pin continuity is fine. I have not had a really easy ride with this board as everybody will have found how fragile they can seem and myopia and the tea time thirst can make things difficult. IS there a mute function that I have activated? If it is ouputting to it's own dac then there must be output that I can tap. Very odd and I have yet to hear the promise of this transport which is very frustrating.
Help!!!
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
