Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 2nd July 2008, 02:09 PM   #1241
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
say that you have 8V in supply
say that you use any ordinary led (green, red , yellow) and they all are in range of 2V of working voltage
say that you don't need full brightness , forr what you need 20mA through led
say that you choose 10mA tyhrough led ( for my eyes always almodst too bright , too)
so - needed resistor is :
(Upsu - Uled)/Iled
(8V-2V)/0,01A = 600 ohms
use nearest bigger value - 620 ohms
dissipation in resistor = I^2xR = 0,01^2x620 = 0,06W , so plain 1/4W is good enough
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd July 2008, 02:26 PM   #1242
Zigis is offline Zigis  Latvia
Very good calculation, Zen Mod!
However I use Cmoy amp powered by 9V bat. and use 10K resistor. with blue LED is VERY bright, with green,red normal bright.
If LED not work at all, there is not resistor value problem, some thing els is wrong.
Zigis.
Old 2nd July 2008, 02:31 PM   #1243
Zen Mod's Avatar
Zigis.
you're right for both things ;
in any case - most led will be bright enough even with 1mA through them
Old 3rd July 2008, 10:51 AM   #1244
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
Yesterday I checked everything again...and everything was okay so........
The best thing for me now is to built up the other boombox the JVC RC-EZ31 tomorrow and just put the 8V power supply to the motorboard (and line up dig out) that must do the trick.......
To baldly go where no man has gone before................(James Kirk)
Old 3rd July 2008, 12:55 PM   #1245
Erik, after searching and stopping display show numbers of tracks or 00 ?
Old 3rd July 2008, 08:36 PM   #1246
No the display has neither light nor movement...it rotates but too fast to read toc.....and after a while it stops...
On the board I did remove the 100nano for 10 nano (wondercap)
Old 3rd July 2008, 09:06 PM   #1247
kevinkr's Avatar
Did anything else happen prior to changing that cap? I would consider reverting to the original capacitor if you find nothing obvious.
Sounds like the micro-controller/dsp is not getting powered properly or has no clock.. Check the ribbon to the display and make sure it is oriented properly. (You didn't plug in the ribbon backwards did you - on EZ32 this can be fatal.)
Check the clock make sure that it is present.
Check the ribbon cable that goes from the laser to the board - make sure it is seated properly and plugged in the right way. (Look at your rcez31 if you need a guide.)
Carefully recheck all of the work you have done since you last had it working and be careful...
Watch out for broken ribbon cables as they are easily broken and not too easy to replace.
I blew the controller in my first rcez32 and had to get another boom box so I know all about frustration..
On a good note mine is all finished and has been working great for about 2 months now. I am very pleased with the overall result and use it nearly every day.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th July 2008, 12:32 PM   #1248
Today I did put up the other rig....the -31
I left eveything standard ...and attached the new power supply
and had immediately a beautiful LOCK...
Music Maestro......
At least I have now all the time in the world to check the-51 careful with the use of your tips...thanks Kevin....
Her a pic....The Brothers 51 31
Old 4th July 2008, 12:33 PM   #1249
My power supply.....
Old 4th July 2008, 12:37 PM   #1250
....and what a lovely sight....partially modded -31....
But what I find strange is that with the 8 Volt only to the motor and no further supply my led is also lid....
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
