Finally, an affordable CD Transport: the Shigaclone story - Page 124 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th June 2008, 07:52 PM   #1231
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I didn't get the clamp yet.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th June 2008, 02:30 AM   #1232
okapi is offline okapi  United States
okapi's Avatar
my clamp progress has been slowed by a lot of work related travel. i have been in okinawa for three weeks and shortly after i return i am off to colorado for a week.
i am concerned that the center bore is not running straight on the clamp. with such a long and narrow bore the tool might be pushing off center. i need to quantify this problem and possibly make some design changes before i proceed.
Old 30th June 2008, 09:47 AM   #1233
Erik van Voorst's Avatar
Thanks for the reply and again lots of respect that you are willing to take all that trouble
To baldly go where no man has gone before................(James Kirk)
Old 30th June 2008, 01:58 PM   #1234
JC Fardo's Avatar
My first test
All mods are as per Okapi´s PDF. Source V+ is 7.97V, 300/100R at Dout, 10nf ERO 1830. Only the crystal oscilator is stock. First impressions are very positive.
Thanks Peter, Algar, Okapi, Audio1st....
JC
Old 1st July 2008, 12:38 PM   #1235
Originally posted by Erik van Voorst
That is the right tool....
BTW I hope Okapi will take orders in a group buy what he mentioned earlier on otherwise I am most certainly interested in your offer...anyway I am interested in your pics of the clamp..
Peter are you using Okapi's clamp at the moment or are you also waiting untill Okapi finds time to help out....
In my opinion, a three leg pulley clamp is better still. Reason behind is the bending stress is well evenly distributed, think can get a cheap one from a local hardware shop. This Three leg gear puller is from China. USD10??
Old 2nd July 2008, 06:23 AM   #1236
Which -51 builder can help...
I have build a dedicated powersupply 8 Volts and fed it direct to the motor (on the choke position).
I also fed the led with 5 Volts direct (orange and grey wiring)
By doing so I could remove the main board and ps board...
When firing up....the disc started to turn like mad...searching.......and stopped.....and the led whas not lit....
Measuring and checking and everything was okay
Old 2nd July 2008, 09:38 AM   #1237
audio1st's Avatar
Hi Erik,
Lets start with the LED, orange wire is NEGATIVE and the grey wire next to the orange is positive. You will need to add a series resistor as well.
If you have 8 volts and the polarity correct, I can't see why you will have a problem with the transport..
Old 2nd July 2008, 11:16 AM   #1238
Thanks for such quick reply
If You mean the 10K I have done that...
I will check polarity again tonight...
Old 2nd July 2008, 02:00 PM   #1239
audio1st's Avatar
Erik, your LED may not be working because the voltage is to low. The 10k resistor is based on having up to 25v of supply. If you have a separate 5v supply, then 1k is more than enough..
Old 2nd July 2008, 02:04 PM   #1240
Yes I came to know when I measured
so I tried even without the resistor
Copyright ©1999-2017 diyAudio
