| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1221 | |
Is it possible to separate the display screen from the white bracket? Thanks Edit: Forgot to mention. What is the pourpose of the misterious component in the red rectangle on the left, connected to a black wire?.
Jose Carlos |
#1222 |
Got the Wyde Eye cable today. This is a 75 ohm cable with real 75 ohm bnc connectors - they sell it as a word clock cable pn WE-BB. I have real 75 bnc on both the transport and the dac and the source and termination are actually 75 ohms - go figure. (I'm an EE..)
Anyway this set up sounds at least as good as the mystery prototype spdif (High end) cable I was given eons ago to evaluate which required kludgy adaptors to use with the bnc jacks on my gear. Not too expensive compared to the usual high end cable tom-foolery, and it really does seem to be a little better than the very good cable it replaced.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#1223 |
I'm not sure which length you got, but 6ft length usually sounds better than 3 ft, at least that was the case with Belkin I'm using
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1224 | |
#1225 |
YESSS...I soldered the 300/100 resistors in place...and received a beautiful lock...spot on.....
I bought a nice 2 x 8 V trafo CT and the blackgates FK 1000/35 and N 1000/50 as well as the MRS860 but then the MRS560 (according to the shops advice) and a heatsink and breadboard so if it keeps raining I know what to do tomorrow....
To baldly go where no man has gone before................(James Kirk) |
#1226 |
....and some figures I was looking for....
#1227 | |
My digital interconnect is actually rather short, only 18" - I've tried longer cables and very long ones occasionally do perform better. Not sure when the reflection arrives back at the input receiver, but so far I have not heard audible degradation with a couple of very short cables I've tried.. Most of my commercial spdif cables are odd lengths, but I have tried standard 75 ohm coax in varying lengths and it was always worse sounding than any of the specifically spdif cables I have.. No real idea why, presumably a TDR would answer that question...
#1228 |
Must admit that with those resistors "The PitBull" becomes a different ballgame...!!!!!!!!!!
I am really enjoying cd after cd and finally can understand the hype....you simply can here the potential...IT IS THERE... I most definitely am going to invest time and money...
#1229 | |
Hi Here is a picture of puller for you: |
#1230 |
That is the right tool....
BTW I hope Okapi will take orders in a group buy what he mentioned earlier on otherwise I am most certainly interested in your offer...anyway I am interested in your pics of the clamp.. Peter are you using Okapi's clamp at the moment or are you also waiting untill Okapi finds time to help out....
