Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st May 2008, 02:49 PM   #1111
Hello!
It "works": the disk is actually spinning (some wobbling though), and there is something coming out of the DAC (I am using Peter's DAC).
However, the sound is far from clear: I can figure out a structure in the sound, but that cannot be called music.
I did all the mods suggested in the .pdf of okapi, and plugged the "Dout" and "GND" to feed the DAC, but I have not used the 2 items of A2 and A1 (2 blue resistors BERN5501000 AND BERN5503010).
I also did the jumper 5A to 5B.
Am I missing something?
By the way, this is a very exciting project. I am having a ball, but circuits are my weakness.
Thanks!
Old 31st May 2008, 05:11 PM   #1112
JC Fardo's Avatar
Default Just for the record
According to Okapi´s mods.
[IMG]CAP 3 & 4[/IMG]
Jose Carlos
Old 31st May 2008, 05:16 PM   #1113
kevinkr's Avatar
Originally posted by Pendergast
Hello!
Thanks!
Are those two resistors you mention the ones used on Dout (spdif) - if so your dac may not like the nearly 5Vpp present on Dout. Use the resistors.
www.kta-hifi.net
Old 31st May 2008, 05:17 PM   #1114
José.
I did remove cap 3 and 4. The only thing I have done differently was to not put the rikens.
The DAC orks perfectly also; I have been using it daily for several hours a day for the last year or so without a problem.
Old 31st May 2008, 05:28 PM   #1115
OK, but which should I use where?
BE RN5501000 and BE RN5503010
I cannot find references as to where these should go...
Old 31st May 2008, 05:33 PM   #1116
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Those are 100ohm and 300ohm.
300ohm is series resistor (A1), 100ohm is shunt (A2), if you follow Okapi's mods.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 31st May 2008, 05:52 PM   #1117
That was it!!!!
I guess I had a wrong version of Okapi's .pdf because it referred to Vishay's and Caddocks so I was confused...
But it is working now, and the sound is clear: music!
This is so exciting!!!!
Thank you so much for this project! Thank you all as well for the pictures and suggestions!
Woaw!
Old 31st May 2008, 10:12 PM   #1118
Little note on suspension.
I am using 1/4 - 20 oven bolts to attach the transport to a 3/4 inch plywood piece (russian birch) and use the green fluo rubber coming with the original set.
A 170 pound man falling from six inches cannot make it skip...
The plywood base of the transport is supported by three spikes. The chassis will be an aluminum cover, with a surrounding box in Jerusalem Gold stone, 1 inch thick, 6 inches high by 8 inches in width, and 10 inches in lenght. The power supply will be external.
The transport itseld should weight about 25 pounds minimum.
No need for springs I think...
Old 1st June 2008, 12:47 AM   #1119
r8833 is offline r8833  Canada
I also prefer transport mounted on wood slightly less mechanical sounding..
Old 1st June 2008, 07:00 AM   #1120
Can u post pictures? Thanks...
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jazz35
Page generated in 0.14870 seconds (73.94% PHP - 26.06% MySQL) with 11 queries
