Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 27th May 2008, 01:22 PM   #1071
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Originally posted by dantwomey
I have a Shigaclone size problem I have to sort out. I successfully had all the smd's removed and ran the wire from 5a to 5b. I also successfully removed all the R's on the palyermods.pdf. Now, I installed all the BG's and the new crystal and I now have an inoperable shigaclone. It spins up and reads "00" on the display. Hints anyone where I might have went wrong?
Dan
Hi Dan, make sure you haven't shorted one of the outside crystal pads to the unused centre pad. Did you reconnect the laser ribbon?
Old 27th May 2008, 01:49 PM   #1072
audio1st's Avatar
Need a 100VA Transformer in UK? low cost, last few.FARNELL
Old 27th May 2008, 02:13 PM   #1073
Puffin is offline Puffin  United Kingdom
dantwomey. I had this problem after having disconnected the laser ribbon. It seems that this needs to be pushed full home to make the thing work, e.g pads amd remote control.
Old 27th May 2008, 02:19 PM   #1074
d to the g is offline d to the g  United States
d to the g's Avatar
Originally posted by Algar_emi
Still get one EZ31 left. I was at an other store in Montreal this weekend with a friend, and found three EZ31 there. So, after this one, I can still get a few...
I'm looking for an EZ31 unit if you've still got one available. I emailed you via the forum button.
Old 27th May 2008, 02:34 PM   #1075
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Originally posted by thekop-bkk
I would like to thx Peter for sharing with us this great transport.
I would like to share my experience with the RCZ31.
, first listening feel that the sound is not better than my CD-Pro2M unit. T
Thanks thekop for comments.
How do you compare CD-Pro2M to RCZ31 after mods?
JC
Old 27th May 2008, 09:23 PM   #1076
JC Fardo's Avatar
Algar_emi
EZ31 pack has arrived
Thanks a lot again
JC
Old 27th May 2008, 11:45 PM   #1077
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
You're welcome. I still have one EZ31 parts kit to sell, and the possibility to get three other one, if the is some real interest.
Old 28th May 2008, 03:53 AM   #1078
okapi is offline okapi  United States
okapi's Avatar
Default clamp update
1. i spoke with the machine shop forman today. he won't give me a definite estimate until i confirm the tolerances on the center hole and the cd shaft. he tentatively said $75 each made out of delran for a run of 50. other materials will raise the cost. have any others been able to obtain a estimate? i will start a group buy thread once i get the final price.
2. i can confirm the center hole measurement for acrylic. the reamer i used worked perfectly. i heated the bottom of the clamp to 120 degrees farenheit (49 degrees C) and it slid on to the motor shaft with a reasonable amount of pressure. going from room temp to 49 C increased the hole daimeter by approx 0.03 mm. i am not sure that the same diameter hole would work with other materials. does anyone know the expansion coefficients for acrylic, lexan, and delran? i could test these materials but this takes time - something i am running short of lately. how do those interested in a clamp feel about this fitting method?
3. i made a puller (see pic) to remove the old clamp. works well. unfortunately i think i bent the motor shaft when trying to remove the clamp before i had made the puller. does anyone have a spare drive motor from a dead mechanism they would be willing to part with?
4. the clamp as it stands does impede screw access significantly. i think the diameter of the bottom section of the clamp should be adjusted accordingly. please make alternative suggestions.
that's it for now. this post was a little rushed but i wanted to update everyone asap.
Old 28th May 2008, 12:39 PM   #1079
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
not everyone will have access to a custom puller. Are there any other options for removing the stock assembly?
Old 28th May 2008, 01:01 PM   #1080
okapi's Avatar
Default Re: CD Clamp
see this post
also, i would be willing to have my puller make the rounds once i am done with it.
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
