Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 24th May 2008, 12:50 PM   #1041
dantwomey is offline dantwomey  Canada
And the very expensive but very nice Bulgins.
Dan
Old 24th May 2008, 12:51 PM   #1042
Puffin is offline Puffin  United Kingdom
Audio1st. Looks great, but what does it sound like. I remember you made one mounted in a (Bamboo ?) chopping board ?. I have some off cuts of granite lying around. What's the difference sound wise between Wood (Bamboo) and Granite ?
Old 24th May 2008, 03:31 PM   #1043
superhkm is offline superhkm  Norway
Default switches
And the Flatfish switches, how do they operate ?
Old 24th May 2008, 03:48 PM   #1044
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
The Flatfish is using a toggle switch called TOC/Stop that is the "Door Closed" switch. Flip it to read the CD TOC (Table of Content) then flip the play switch:
There are four tiny toggle switches: for power, selecting tracks, pause and play, and one marked Stop/TOC. You have to flick the Stop/TOC switch or the Flatfish won’t read the entire CD if the previous CD you played had fewer tracks. For instance, if the previous CD had ten tracks, that is all the Flatfish will recognize on a subsequent disc until you click the switch to identify the contents of the new disc. However, if you Stop/TOC a disc with, say, 20 tracks, you should be covered for most CDs that follow
Just a few reviews:
http://www.positive-feedback.com/Iss...bsflatfish.htm
http://www.soundstage.com/revequip/4...rogression.htm
http://www.enjoythemusic.com/Magazin...600/47labs.htm
http://www.dagogo.com/47LabFlatfishP...ionReview.html
http://www.stereotimes.com/trans050802.shtml
http://www.onhifi.com/product/47labs_products.htm
http://www.6moons.com/audioreviews/47lab/shigaraki.html
Sold one EZ31 to JimS, just one left to sell.
Old 24th May 2008, 06:45 PM   #1045
The switches I have in my partsbox stay open or they stay closed, and can not be used as a substitute for pushbuttons. But I like the look of the flatfish switches, how do I specify this functionality ?
What I want is a " off - (on) " configuration , correct ?
The closest I get is (on)-off-(on) (on rsonline), but there is a difference between DPDT and DPST contact configuration , anyone care to clarify on this?
I guess that properly wired I can get a (on )-off -(on) to select tracks back and forth , and maybe play / pause ... ha.. am I answering my own question ?
Old 24th May 2008, 11:32 PM   #1046
kevinkr's Avatar
Default Re: These may be cheesy
normally open switch
normally closed switch
From MPJA @ $0.29 ea.
Whadaya think?
...100?...200?...
I'm using essentially this very switch, and it works fine.. I tried some of the other larger types and while they look nice, the feel is not so good.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 25th May 2008, 02:06 AM   #1047
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Originally posted by audio1st
Just add the 18mm MDF top and sit the granite base on three soft feet (or two soft feet and a spike).
All done...
Thanks audio1st
Did you consider adding Daruma roller blocks underneath.
Daruma
JC
Old 25th May 2008, 08:06 AM   #1048
Bump.
Old 25th May 2008, 08:59 AM   #1049
Zoran is offline Zoran  Serbia
Hi
i ordered a RC-EZ31B
and
SF-P101N-15 PIN
mechanism, like future replacement opt
from the local store
Is that a right transport mech. for the transport from ez31 ?
thanks
Old 25th May 2008, 07:21 PM   #1050
nickthevoice is offline nickthevoice  Canada
what do you do for LED DISPLAY ?
because I need 0.6 VDC for back light + what's SYNC1 and SYNC2 ?
other question:
The crystal oscillator to change for Citizen 300-8441 it's X901 ?
thanks in advance !
nicK
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
