Finally, an affordable CD Transport: the Shigaclone story - Page 104 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd May 2008, 11:54 AM   #1031
I'm in the way to build this TRANSPORT with EZ31 but
how do you make a good finish look with EZ31 control board. (PLAY STOP buttons ?)
if you have pics of finished transport front panel please ?
THANKS
nicK
Old 24th May 2008, 12:37 AM   #1032
Algar_emi's Avatar
Still two EZ31 left. They won't last much longer. I'll return them at the end of the week, because I'll be gone from home for almost all the month of June.
Old 24th May 2008, 12:50 AM   #1033
My Shigaraki is up and running. I had all SMD's removed today and then removed all 'R's in the playermods.pdf. I then ran the wire from 5A to 5B. Although in stock form this transport is not a giant killer in terms of air and treble extension it's still very good with no obvious vices. Very well balanced and listenable. I can't wait to get the BG's in and let it burn in!
Dan
P.S. It's currently feeding one of Peter's NOS TDA1543 DACs.
Old 24th May 2008, 12:53 AM   #1034
r8833 is offline r8833  Canada
here's what I did with original front panel and 3 walmart cutting boards
Old 24th May 2008, 08:08 AM   #1035
Puffin is offline Puffin  United Kingdom
r8833. I intend to do the same with the old case, so that it covers the IR remote panel etc.
Old 24th May 2008, 10:22 AM   #1036
audio1st's Avatar
For those of you not going the Bronze and Copper enclosure route, then here is another suggestion.
I have used an old Goodmans unit for this (same chips), but it would work equally well with the JVC.
The transport is directly connected to a couple of bolts bonded to a granite board.
I also replaced the original clamp and motor for a low mass, three point clamp I salvaged from another unit.
Old 24th May 2008, 10:24 AM   #1037
audio1st's Avatar
I then added an 18mm MDF surround and switches. The switches are the (on) off (on) type and are connected in parallel with the original push buttons.
Old 24th May 2008, 10:25 AM   #1038
audio1st's Avatar
Just add the 18mm MDF top and sit the granite base on three soft feet (or two soft feet and a spike).
All done...
Old 24th May 2008, 10:58 AM   #1039
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Default These may be cheesy
normally open switch
normally closed switch
From MPJA @ $0.29 ea.
Whadaya think?
...100?...200?...
Old 24th May 2008, 11:08 AM   #1040
BeAuTiFuL cd transport AUDIO1st !
You give me the idea to change the buttons for "momentary ON push button" for case. (available in ALL COLOR)
Thanks for PICS !
nicK
Copyright 1999-2017 diyAudio
