Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 21st May 2008, 09:11 PM   #1021
DaveM is offline DaveM  United States
DaveM's Avatar
All of this is a bit of nit picking and I don't want to get you nervous that you are doing something wrong, because you are not. It looks like you are doing great work. I just can never leave well enough alone and the engineer in me wants to make it as good as it can be.
When cutting Delrin on a manual machine I don't use coolant. On the NC we use synthetic water based coolant.
I think that you are confused with question 2. Delrin doesn't get brittle. At least that I know of. Acrylic is the brittle one. Delrin is usually suggested as a metal replacement material when weight and cost are an issue. The stuff is tough and can be hammered on without cracking. If you are concerned about cracking with the press fit of the shaft, then Acrylic would be the material to avoid.
The other thing to keep in mind is that if a pro shop is doing this on an NC machine, they will not care about seeing the bore, they will program it and then run it with coolant running. In other words the tool will be cutting in a hose of water and coolant. Heat is really not an issue then.
Simply put, if the amber color is a priority, the go for it. If clear is just as good, the I would say use Lexan. If you are cool with black, I would use Delrin.
Old 22nd May 2008, 01:02 AM   #1022
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
2 more parts kits are available. I bought the last EZ31 that had this store (my wife did it for me). So again, if you have problem to find it, send me an email. I'll keep them for two weeks.
Old 22nd May 2008, 09:20 AM   #1023
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Default CD Clamp
audio1st. did you remove your old clamp to test a Play station clamp? i ask because i tried to remove my clamp but was unable to do it with force levels that i felt wouldn't dammage the drive shaft.
A picture of how to use external Circlip pliers to remove clamp from shaft.
Old 22nd May 2008, 09:43 AM   #1024
audio1st's Avatar
Default CD Clamp
Hi Okapi,
A couple of points about the replacement clamp.
Do you have to drill the 2mm hole the full length of the clamp including the threaded part (the shaft is only 18mm long)?
The original clamp has 9mm of friction fit, the new clamp will have 18mm of friction fit. This will make it very difficult to fit or remove. I say remove because once it is in place, you will not be able to access the motor mounting screws to gain access to the cct board.(the base of the clamp may even touch these screws)..
Old 22nd May 2008, 04:03 PM   #1025
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Should someone search new on stock
TDA1541A-S1 (single crown) DAC's
or
CS8412-CP Receiver (DIL)
You may have a look into the diyaudio marketplace, parts and supplies...
Franz
Old 22nd May 2008, 04:11 PM   #1026
DaveM's Avatar
The idea of machining the hole all the way through is so that in one chucking of the part you can cut the CD mounting surface as well and the shaft hole. This will give you best results in terms of runnout and concentricity. If you try and do it in 2 setups the parts will definitely not be as good.
Make it shorter if needed, but the hole through is there for the above reasons. I would suggest getting a space of the right thickness and when mounting the clamp, press it down until it hits the spacer. The mounting height should be pretty important.
Old 22nd May 2008, 04:49 PM   #1027
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
Default Re: CD Clamp
The hole needs to be through the full length, otherwise compressed air could make it impossible to push the clamp in.
I calculated the dimensions so the base should not touch the motor mounting screws.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 22nd May 2008, 07:52 PM   #1028
okapi is offline okapi  United States
okapi's Avatar
clamp aficionado's,
been a little too busy to reply but i have been paying attention to the comments.
removing the motor mount screws will be a little more difficult with the new clamp in place. i am thinking of replacing the screws with bolts to make side access easier. anyone know the screw size?
fitting the clamp on the shaft is something i still need to test, however, i still have not removed the old clamp (going to fabricate a puller) so i am unable to begin testing. i have several ideas on how to approach any potential problems that i will discuss here before taking action if they become relevant. i should have tested fit before i constructed the clamp but i think things will still work out.
as suggested, i am going to use a spacer to put the clamp in the proper position. i was able to find a washer that was exactly 1 mm thick. i just cut an opening in it so it can slide around the shaft.
Old 22nd May 2008, 08:36 PM   #1029
DaveM's Avatar
I just have to say. I love the way that pieces that I don't know or leave out or simply forget to write seem to be filled in by others.
Very cool
Old 23rd May 2008, 06:24 AM   #1030
superhkm is offline superhkm  Norway
Default germans , beware !
http://cgi.ebay.de/JVC-RC-EZ31B-CD-S...QQcmdZViewItem
there is one available on ebay.de
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
