Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st May 2008, 12:56 AM   #1001
Algar_emi's Avatar
Yes, indeed. I'm certainly in for one clamp, if available
Old 21st May 2008, 06:58 AM   #1002
Default clamp me up please
I'm amazed by the resources you people have.
I really want in on that that groupbuy, I ust received my 31b, and the magnetic clamp does not look good, uncentered and undamped.
BTW , you just short the "door switch" connector, right ?
Old 21st May 2008, 07:57 AM   #1003
Default Clamp
If anyone is making a list of those interested in a clamp please include me too. Thanks!
-claiborne
Old 21st May 2008, 02:04 PM   #1004
DaveM is offline DaveM  United States
DaveM's Avatar
You don't want to just short the door switch. It is needed to make the player read the TOC. I plan to make that a momentary on switch. The idea being to hit the switch every time you change disc, causing the player to register the discs content.
Old 21st May 2008, 02:14 PM   #1005
Puffin is online now Puffin  United Kingdom
DaveM. Don't you mean momentarily "Off". These are not so easy to find in my experience.
Old 21st May 2008, 02:15 PM   #1006
JC Fardo's Avatar
Iīm a bit confused about that. I think the "CD door closed" status switch is not momentary.
Thanks for corrections.
Jose Carlos
Old 21st May 2008, 02:19 PM   #1007
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
In the original "box" the switch opens when the door opens and closes and stays closed when CD is put in.
A momentary switch may work because once TOC is read...it stays read! ...i think! havenīt tried it yet, just got my EZ51s yesterday.
Old 21st May 2008, 02:33 PM   #1008
JC Fardo's Avatar
Grande CV!
Thanks for clarification
Jose Carlos
Old 21st May 2008, 02:41 PM   #1009
kevinkr's Avatar
Both very easily found on eBay.. I have recently purchased both NC and NO momentary switches there. They even match.
I tried the NC momentary approach, but found it less stellar than I had supposed. When you turn on the player it will immediately attempt to read the toc whether or not there is a disk on the platter - I found this more than a little annoying and ended up going right back to the toggle switch I originally had. I can set this to "open" before powering up the player, power up the player and then put the disk I want to play on the platter, close the switch and hit play. Works like a charm.
www.kta-hifi.net
Old 21st May 2008, 02:43 PM   #1010
kevinkr's Avatar
A NC momentary will work, however an NO will not. The player needs the door closed signal in order to initiate toc read and play. Using an NC momentary will result in an attempt to read the toc every time you turn on the player. I found this beyond annoying.
www.kta-hifi.net
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Page generated in 0.14612 seconds (70.25% PHP - 29.75% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
