| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I just recieved a Arcam service manual for has a CDM1 MKII alignment procedure. I attempted alignment according to the manual but It didn't work out. (My unit is a Krell) I started by setting the laser pot at 780 as recomended by service manual(1k across the 2 resistors in series) and the focus in the middle. I was able to achieve a 50mv dc across the laser test point but when I adjust focus at 400mv and stop it would not play again. I finally adjust focus to 225 mv to get a stable playable signal. I didn't have the original philips test disc so I used a burousch alignment disk with 1khz sine wave. Being frustrated I found the eye pattern and attempted to adjust both laser and focus but neither made a noticable difference in the eye pattern Does anyone know what values I should adjust for with the burousch disk or should I attempt to find the super rare philips disc?
#2 |
Magneto the Gravity Man
It could just be the laser on the way out.
#3 |
To Poyton-Thanks for reply I 've thought about that. I don't believe the laser is weak because I was able to attain 50 mv without going over the 1.23 volt limit across the laser diode current resistor. It was only .95 volt. I guess it could have an internal focus issue within the pickup assembly. Do you know if these can be taken apart to clean the internal lenses. I've fixed several playstations by cleaning the internal lenses.
#4 | |
I've never done it nor have I heard of it being done. It's easy to get a new assembly (cdm-4) or a second used of Ebay. http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=010 Andy |
#5 |
It sounds to me like you simply need to turn the platter motor bottom thrust bearing in a half turn or so to compensate for bearing surface wear. The lasers on the CDM1 series are as close to infinitely durable as any I've seen in 25 years of servicing, so, agree, laser is most assuredly just fine.
#6 |
To Stephen-Thanks for reply. The 2 screws on the bottom of the servo disc motor are turned clockwise as far as they can go. Should they be turned counter clockwise hallf a turn? I saw a diagram in the philips 880 service manual that showed a mechanical alignment for this but I could not read german to understand it.
#7 |
I was referring to the actual bearing part of the motor bottomplate, which is a threaded piece of some sort of dark brown ceramic material, with a torx driver hole to turn it for height adjustment. It will be right in the middle, under the platter motor shaft.
#8 |
Stephen-here is picture of cdm1mkII. Is it the black piece in the bottom part of pic are talking about?
#9 |
My error. I'm afraid I had the earlier CDM-1 version in my head. Yours doesn't have that adjustment. Your symptom description does suggest that sort of problem, though, i.e., bearing wear causing platter height to decrease. Don't recall an adjustment for this on the mkII unit, off hand.
#10 |
Thanks for the replies. In that case I guess I need a whole pickup assembly. I never see these for sale on US ebay. If anyone sees a silver cdm1mkII pickup for sale in another country please let me know.
| CDM1 MkII gurus - need your help! | tonyptony | Digital Source | 18 | 1st June 2009 09:25 PM |
| Philips CDM1 MKII = CDM2?? | FC5687 | Digital Source | 2 | 4th July 2007 11:32 AM |
| How do i do simple mods to a CDM1 MKII based transport? | bryanj | Digital Source | 5 | 1st March 2005 09:22 PM |
| Cdm1 Mkii? | Rotellian | Digital Source | 7 | 29th March 2004 09:16 PM |
| Wanted: Philips CDM1 MkII laser | LeoJar | Swap Meet | 3 | 22nd June 2003 05:25 AM |
| Page generated in 0.10817 seconds (77.50% PHP - 22.50% MySQL) with 11 queries |
