| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi, this is my first post on the digital forum.
I want to use a yss901 crosstalk canceller dsp chip from a tv audio board to operate as an external device between my cd player and preamp. fcserei is guiding me-he has already done it (inserting the chip into a digital amp)-in another thread. See: try ambiophonics with your speakers. The problem is I know nothing about digital audio and need to have a lot of things explained. He indicated that I need a spdif receiver before the chip and a transceiver after it. He mentioned the cs8404 or similar. Why do I need these receivers? After a google search I understand it extracts some necessary digital information. Will I have to hook some leg from the yss to this receiver chip for syncronization? Or the receiver circuit will pass these data to the yss along the spdif cable? Finally, where can I find a suitable receiver/transceiver implementation that I can use? I have found dacs use them but they donīt seem to exist as standalone boards. J Just found this. Could this be ithttp://www.audiotuning.de/english/in...53-cs8414.html |
#2 |
or could I use this without the smaller chip (a DAC):
#3 |
I love cats and I will help.
![]() First, you just have that chip or you have the whole implimented board? Second, do you know it's inputs and outputs? i2s perhaps? I presume your preamp is a normal analog preamp, not the digital one that recieve spdif. Then you can focus on your CD player. You tap the dac chip's i2s input to your dsp chip input then put your dsp output back to the dac chip. you could design some kind of bypass when you want to compare the sound while your dsp chip is operating or bypassed. (this feature might be included on your dsp chip already pls check) If you mean digital preamp, then the basic is the same but you have to do it before the preamp dac chip.
#4 |
Thanks,
I have the full board, not just the chip. It has both analogue and digital inputs and outputs. I donīt know what i2s means? Fcserei advised me to disconnect the noisy power supplies on the board and use a clean 5v, which Iīll do. My preamp/amp is the yamaha ax1, with digital inputs, but I wouldnīt dare to tinker inside. My source is a denon 2900 and the idea of tapping into its circuitry scares me without someoneīs guidance. So my idea is to put the crosstalk canceller board in a box with its own power supply. Iīve found a spdif board from twistedpear audio thatīs not expensive. But I could buy an inexpensive cd player and tap into it as you suggest. Would that spare the need for the spdif transceiver? Which option is more foolproof for an inexpert hand? Hereīs the yssīboard and the spdif specifications: http://www.twistedpearaudio.com/opus/opus.aspx |
#5 |
Account Disabled
I'm interested in this chip, or the FIR filter used so I can play around with it on a PC (or is there equivalent software?), but I'm having trouble finding information. Any pointers?
#6 |
abzug,
Google the words: yss901 stero dipole You will find a comprehensive pdf from yamaha. The chip is obtainable from the sony sdm n50 video monitor. |
#7 |
i can see your chip using i2s. for more info about i2s, check out wikipedia.org
so your choice now would be:- - get spdif out from your cd player / convert it to i2s / feed your dsp chip / get i2s out converted back to spdif to feed your digital amp. (please check if your amp also accept i2s but i wouldn't think so) - start with your new cd player / tap those i2s signal out to feed your amp / tab it back to your dac (with some kind of switch/circuit/) / get analog output to feed your amp. if i were you, my own choice would be to build a new dac with that dsp chip also in. from those of your two choice it is close to a new dac already.
#8 |
I quite enjoy using the ampīs digital hall effects. So Iīd rather keep the yss insertion in the digital domain and avoid converting twice.
Of the two alternatives you described the first seems to suit me better since it remains digital and as a plus I will end up with a external box that I can use with any cd player in the future. ( my denon has already become finicky and will not read certain cdīs). So, focusing on this route: I see I2s consists of word select, serial clock and serial data. I need spdif receivers that provide those connections both before and after the chip. I have found a commercially available receiver board from twisted pear audio that I could order if you would confirm it might work. http://www.twistedpearaudio.com/docs/wm8804/wm8804_manual.pdf I have a huge sweet spot for cats.
#9 | |
Try page 8 of the YSS901 datasheet. |
#10 |
I have already ordered the receiver boards.
Despite the non-standard I2s, the yss901 can adopt four different data formats. I have been advised on the other thread that one of them will likely work. Iīll keep my fingers crossed Hereīs the receiver layout. Now I just need to know how to connect the boards. Before any further detail, the receiverīs spdif goes to the cd playerīs digital out and the yss connects to the aif connector? http://www.twistedpearaudio.com/imag...804_layout.jpg |
| Clueless.. | Newbie33 | Introductions | 3 | 24th November 2008 10:05 PM |
| Newbie question Mission 761's | Bob_Sled | Multi-Way | 1 | 12th January 2008 08:40 PM |
| Newbie Question on tweaking Mission M71 | ewhale | Multi-Way | 4 | 3rd December 2005 02:39 PM |
| clueless needs help | Vista | Multi-Way | 2 | 22nd February 2003 08:40 AM |
| Page generated in 0.11609 seconds (79.82% PHP - 20.18% MySQL) with 11 queries |
