| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi All,
Need some advice. Aside from low noise, how does the TL431 sound with pre- regulation when used in a dac ? Sorry, I know this is subjective but would like to hear your opinions especially when applied to the TDA1541a dac. Thanks to all |
#2 |
Well, my first 1541 DAC used single, 78xx based regulation, and it didn't sound as good as my second DAC, dual regulated lm3x7 followed by TL431.
There may well be better out there, and I haven't measured performance, but it does work well. |
#3 |
Thanks for sharing your experience |
#4 |
the TL431 is a shunt regulator. What limits the shunt current if the preceding regulator is a series type?
regards Andrew T. |
#5 |
Hi AndrewT,
If I understand the question correctly, I use a resistance to limit the current before the TL431. I think I use about 100R. Seems to work okay. Is that what you mean? Cheers, Phil |
#6 | |
Alternatively, set up the LM317 as a current source to replace both the pre-regulator and the resistor.
regards Andrew T. |
#7 |
Unfortunately, the pre-regulator feeds other circuits, so using it as a current source isn't really an option.
Is the 317 a good current source? |
#8 |
Hi Philpoole,
Actually I'm toying with that idea but using LT1085 & LT1033 as current source to power the 24 TL431. Planning to built EC Design DI8M dac. |
#9 | |
http://waltjung.org/Late_Articles.html As usual, excellent reading! |
#10 |
Hallo.
i want to ask anyone whose know how to calculate R (R1,R2,R3 /R1A,R2A,R2B) value of combination Reg LM317/337 and TL 341 i plant to use for reg +15 -15 output current 300Ma. input volate +- 20V dc output 15V output current 300Ma this the schematic. please heelp anyone. thx |
| LDO regulator PCB design question | BWRX | Power Supplies | 2 | 27th October 2005 09:41 PM |
| A 3-Pin Regulator Question | saurus | Solid State | 3 | 27th October 2003 01:54 PM |
| regulator question | fezz | Parts | 12 | 16th April 2003 03:10 PM |
| Regulator question | Mark Hayenga | Solid State | 2 | 9th January 2003 08:11 PM |
| BOSOZ regulator question | audionut | Pass Labs | 1 | 5th July 2002 04:40 PM |
| Page generated in 0.10314 seconds (73.58% PHP - 26.42% MySQL) with 11 queries |
