Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd February 2008, 01:34 PM   #1
hajame is offline hajame  Hong Kong
hajame's Avatar
Default EAC Drive Detection Problem
The EAC cannot detect my drives - master: pioneer DVDRW , slave: CDRW. But the other software can detect and control them without problem. Any possibilities?
Old 22nd February 2008, 04:04 PM   #2
kevinkr's Avatar
It would help to know a little more about your machine, types of drives (including interface type) and the OS you are using.
If you are not using cable select are the slave and master drives on the correct connections for their selected mode on the interface cable? (ATA)
EAC probably is not compatible with Vista for example..
You may have a subtly damaged download of EAC and could need to download and reinstall it again.
Finally you can always try to contact the author of EAC for advice.
www.kta-hifi.net
Old 22nd February 2008, 09:07 PM   #3
Default eac
load the most current version of Adaptec win_aspi
then re load 99pre_beta 3
http://www.adaptec.com/en-US/speed/s..._471a2_exe.htm
might solve the issue
Old 22nd February 2008, 10:59 PM   #4
hajame's Avatar
Default Re: eac
Thanks! But this doesn't work...
My OS is winxp pro, both drives are IDE and the cable's end is connected to the master and the intermediate plug is connected to the slave. The other end to the motherboard's first IDE socket. Only EAC shows a problem of drive detected but the other programs such as foorbar and win media player do not.
Here is what EAC shows during drive setup
Old 22nd February 2008, 11:04 PM   #5
hajame's Avatar
It shows no track list no matter which drive do I put the CD into.
Old 23rd February 2008, 12:25 AM   #6
kevinkr's Avatar
English language XP? Have you uninstalled and tried reinstalling EAC?
Also what does your bios show at post? Either/both drives detected?
I would contact the developer next.
www.kta-hifi.net
Old 23rd February 2008, 01:48 PM   #7
hajame's Avatar
Oh...I use Chinese winxp... this may be the problem.. The bios definitely shows both of the drives.
Old 23rd February 2008, 06:40 PM   #8
kevinkr's Avatar
I would contact the developer and find out whether or not EAC runs under the Chinese language version of XP, there are differences in some versions of the OS that can occasionally cause problems. In my old job we had all sorts of problems with the Japanese version of XP not running some of our applications correctly.. (Our customers were mostly in Japan - machines we furnished had US version of XP which in an emergency might be replaced temporarily with a machine with Japanese XP on it, didn't always work.)
www.kta-hifi.net
Problem with Kenwood CD drive zcx2007 Digital Source 10 26th September 2008 07:47 AM
Sony PS-X50 direct drive speed problem PTSOUNDLAB Analogue Source 3 26th August 2007 07:24 AM
Hard Drive problem lawbadman Everything Else 20 24th July 2007 01:42 AM
Grundig CD-1 with CDM drive...problem Skorpio Digital Source 1 15th February 2007 04:25 PM
ksm210 drive unit problem ...Please help... hiwiho Digital Source 1 4th October 2004 08:20 PM
Page generated in 0.08684 seconds (84.95% PHP - 15.05% MySQL) with 11 queries
