| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi Guys,
somebody can tell me if possible to replace the KDA0316 DAC by PCM1754. Thank You! Maxpou http://www.datasheetcatalog.com/data.../KDA0316.shtml http://www.datasheetcatalog.com/data.../PCM1754.shtml |
#2 |
It is not pin compatible, so you definitely wouldn't be able to simply remove one and solder in the other.
#3 |
yes i know that i gonna design the PCB, but i would like to know for bit clock input, audio data input, system clock and for the selection of audio data if is compatible. thank you! Maxpou |
#4 |
Audio Engineer
Compairing the two data sheets I don't think it will work. The reason is that the Samsung DAC uses two word clocks; one for left and one for right and they are not present for a complete cycle of the data. I have never seen this before.
The Ti part uses the industry standard method of having one word clock with left indicated by one state of the line and right by the other. If you are good at logic circuits it may be possible to create a circuit to convert the two word clocks into one that is compatible with the TI chip. Regards, Andrew |
#5 |
Thank you for reply!
but where are you found this information? I read the datasheet many time and i dont found it. Maxpou |
#6 |
Audio Engineer
For the samsung part the timing diagrams show the two left right word control clocks WDCLK1 and WDCLCK2 clocks on page 508 in both timming diagram 1 and timming diagram two.
For the BB part the timming diagrams are on page 15 and show just one combined LRCK for left and right word control. Regards, Andrew |
#7 |
All the signals bar BIT CK, LRCK and DATA are irrelevant to the PCM1754. All you need to find or generate is a system clock signal synchronous to the data.
#8 |
Thank you guys for reply,
but you need a other document sorry! In my cd player the dac use only WDCLK1 as in this schematic. rfbrw: can you explain more because i don't understand? thnak you! maxpou |
#9 |
and the DSP
#10 | |
As rfbrw says, all the signals you need are there (LRCK, BCLK, DIN) except for the system or master clock input. I think you can find that on the SM5807 XTI pin. It should be 16.9344MHz, which is suitable for PCM1754. PCM1754 can run at 5V, so level shifting is not required. I think this should work without much trouble, but obviously you need a whole new output stage.
http://audio.gotroot.ca/ |
| Replace transistors | huy801 | Solid State | 3 | 8th February 2008 04:01 AM |
| replace 5y3 | ardan77 | Tubes / Valves | 5 | 15th January 2006 03:41 AM |
| Replace of CDM 4/19 with CDM 4/31? | bezobraznia | Digital Source | 4 | 14th November 2005 03:56 PM |
| what do I replace...? | 9am53 | Tubes / Valves | 10 | 5th May 2005 02:20 AM |
| Page generated in 0.10491 seconds (77.51% PHP - 22.49% MySQL) with 11 queries |
