Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CS8414 spdif problem
Old 12th February 2008, 03:37 PM   #1
pigoia is offline pigoia  Italy
Default CS8414 spdif problem
Hello!
I built this mini dac http://www.jogis-roehrenbude.de/Lese...Projekt/CD.htm
But I change the spdif reciver with the CS8414.
I read many times, this is compatible with mini dac.
I've change the filter 470ohm 0.068uF (CS8412=1K 0.047uF).
When I push play no sound....
At this moment I' haven't a scope but I check the tension.
Pin 28 4.6v (I must be zero when lock spdif)
Pin 26 1.3v
Pin 11 4.6v
Pin 7,22,24 5v
Pin 14,8,21,17,18,23 GND
Any idea?
Old 12th February 2008, 08:03 PM   #2
I tried an old cdrom and now work!!
I check the spdif cable connected:
cdrom work 0,93v
cdrom doesn't work 0,12v
This mean anything?
Old 14th February 2008, 12:15 PM   #3
I solve the problem!
The digital out on the back of cdrom unit, is spdif in ttl format.
I remove R1 (75omh) in input interface, R1 in needed only with coax cable (cdplayer).
But I've an another problem....I bought 3 CS8414 on futurlec.
Only one works, possible other 2 have failure.
In the attach file not work.
Thank you.
Old 14th February 2008, 05:40 PM   #4
kevinkr's Avatar
I see what appear to be a couple of unsoldered pins on your adaptor board - pins 15 and 28 specifically, and there are probably others.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th February 2008, 07:00 PM   #5
This work!
Same adaptor but I see now... different code.
What is this code?
Old 14th February 2008, 07:26 PM   #6
kevinkr's Avatar
That code is the manufacturer code and should tell you where it was packaged and when. If you go the Crystal website it may tell you how to read those codes.
It really does look like some pins are not soldered properly on both of those adaptors and I would address that issue first.
Actually putting spdif receiver chips on carriers like that may not be a wonderful idea, and I bet there is no supply decoupling on that adaptor either, despite the obviously long trace lengths.
Old 14th February 2008, 09:20 PM   #7
Archwn is offline Archwn  United Kingdom
"guala" must be Guala lumpur capital city of Malaysia (or indonesia?)
8414 from my experience, is quite fragile. lots of them fails shortly after a while.
Old 16th February 2008, 11:58 AM   #8
irgendjemand is offline irgendjemand  Europe
to Kevinkr, Archwer and others
If so, could you please advice about using the CS8414 with an adaptor, for example - instead of Yamaha YM3623b? Please see the attached picture: This one is meant to do exactly this (replacing the YM3623). It is configured to 24 bit Input/Output.
Should this be OK?
Many thanks!
Old 16th February 2008, 12:09 PM   #9
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Dammit, spilled coffee all over myself. It's plain irresponsible to insert such a gem into this boring thread.
Old 16th February 2008, 12:18 PM   #10
Sorry about the coffee! And how about ansering the question ?
CS8414 spdif problemHide this!Advertise here!
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 0 26th July 2009 09:28 PM
Problem in reclocking CS8414+TDA1543 DAC ray_ben Digital Source 25 23rd December 2005 05:19 PM
Problem with SPDIF comparator (Elso) tiroth Digital Source 52 29th August 2003 08:11 PM
problem of cs8414 takashi Digital Source 0 19th December 2002 03:16 PM
