| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi!
I'd like to make a discrete output stage for my cd player. It's sound too harh in the highs. I'm looking for a tube sound. I've just tried LM4562 in the place of NE5532 but It sounds quite the same... Someother people advice me to put the OPA2134 ... Actually I'm not so sure that changing opamp I can really get the sound I'm looking for. What do you think about an A class transistor (or Tube EERP) output stage? Who wanna help me? Do you have any ready schemes? Regards, Enzo. P.S. In attached you'll find cd player scheme. |
#2 | |
Magneto the Gravity Man
Moderators : this thread should be in the DIGITAL section |
#3 |
Agreed. Done.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 | |
Discrete is not necessarily better -- esp. if you implement "blindly". Matching impedances and putting the ckt under the o'scope are, IMO, important tools/techniques to get discrete stages to sound best. All that said, and when you're ready for the "next step", here are a few discrete IV's to keep you busy: Peufeu's discrete IV Jocko Homo's discrete IV Rudolf Broertjes' discrete I/V (You noted "tubes". But I don't like them because, to me and all else being equal, they do not reproduce accurate sound when compared to carefully-designed SS ckts, like the ones above) Your schematic shows an opamp-based output buffer. Buffering may or may not be needed depending on certain "criteria". Can someone with knowledge and/or experience -- or just a humble opinion! -- comment on when buffering is or isn’t necessary? |
#5 | |
What CD player are we talking about here.? Your schematic does not show the DAC so I think recommendations are a little premature. Andy |
#6 |
Hi Enzo,
I see you are now trying a different angle. Be patient! Do some research, something called "Due Diligence". You said in the other thread you started, that you are trying to warm up the analog output stage to a "tube like" sound. http://www.diyaudio.com/forums/showt...52#post1417952 This might be do-able with some info: Model we are working with... DAC we are working with.... the right op amp choices that offer a "warmer sound" (AD op amps are very accurate and revealing but I wouldn't say "Tube like") and a bunch of other mods before you decide to go to a "Discrete" output stage. You tried the LM, but did you research the Data Sheet to see the optimal values on the decoupling caps? This can bring the most out of these and other op amps. Not all op amps are just swap and play (op amp rolling). Ignoring to check this isn't the way to see if they are right or wrong. You have to look at the whole output stage when making mods! (most of the time) Also start with op amps that have the desired traits you are looking for (research this, it is all here on DIY somewhere). Andy is right. If we know which CD Player it is, we know what we have to work with and the max potential and if it can be anything special with mods or if it needs replacing the output stage (not to mention everything else). Or if you want to make this kind of commotment, maybe a different used cd player might offer more potential because this one might not be worth it, other than the experience! This is TBD. This can be a great experience and a huge learning opportunity! Good luck! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#7 |
the output stage is not a buffer. It is a 2pole unity gain Sallen & Key low pass filter. Prior to that is a shelving filter. Normally these active filtering opamps need high input impedance to ensure the filter poles are accurate, but Rotel may have altered the component values to take account of the 5532's limited impedance. Simply swapping to a FET input opamp could be undoing Rotel's ingenuity or worse, causing the better opamps to become unstable. How does the MFB looking filter in the I/V section operate? Is it a pure I/V section or does it also operate as a filter? I note that to protect the final opamp in mute mode that Zout=470r has been added and then a further 220r before the RCA fixed outputs. What circuit follows the tappings into the variable output PCB? These unknown loads on the final opamp and the high total source resistance (Rs=690r) will limit what equipment can be supplied with signal.
regards Andrew T. |
#8 |
Hi Andrew!
His schematic doesn't look like a Rotel Schematic.... How did you know that? I hope all is well! Regards//Keith
#9 | |
#10 | |
regards Andrew T. |
| Chipamp with discrete output!!! | Minion | Chip Amps | 4 | 16th March 2008 05:12 PM |
| Op amp based preamp with discrete output | hags | Solid State | 11 | 17th September 2007 09:24 AM |
| Discrete output stage for Sony c222? | Sheldon | Digital Source | 17 | 26th December 2004 08:44 PM |
| CD Player Output Vs. Preamp Output For A Sub. | kspv | Multi-Way | 3 | 16th April 2004 10:45 AM |
| discrete digital out from dvd player as mentioned in Audioxpress | Mark Hathaway | Digital Source | 0 | 13th October 2002 01:29 AM |
| Page generated in 0.14625 seconds (82.73% PHP - 17.27% MySQL) with 11 queries |
