Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th January 2008, 07:45 PM   #1
cbriere is offline cbriere  Canada
Default looking for All BJT i/v output stage
For the PCM1792A, witch is differential.
4 pins : IoutL-, IoutL+, IoutR-, IoutR+
tks
Old 31st January 2008, 04:45 PM   #2
kevinkr's Avatar
You looking to build or looking to buy?
LC Audio makes the Zapfilter which will do exactly what you are looking for.
www.kta-hifi.net
Old 31st January 2008, 06:18 PM   #3
the Zapfilter look good.
I need to build it for myself.
I found the schematics but no par values on it
did someone has builted a clone of the zapfilter?
Old 31st January 2008, 06:22 PM   #4
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Hawksford's scheme uses only BJTs.
Old 31st January 2008, 06:31 PM   #5
Hawksford....... schematics available?
please post link,,,,,tks
Old 31st January 2008, 06:49 PM   #6
kevinkr's Avatar
I was working on something quite similar, but have shelved the project for the time being. (Not enough time in the day.) I might be motivated to resurrect it at some point for my scd-777es project player, but for now its asleep..
www.kta-hifi.net
Old 31st January 2008, 06:56 PM   #7
Geoff is offline Geoff  United Kingdom
http://www.essex.ac.uk/dces/research...lications.html
Old 31st January 2008, 07:29 PM   #8
I found the schem. of Zapfilter clone,,
Searching for ZAPfilter Mk2 clone.
but,
did anyone had succes with this circuit?
Old 6th December 2008, 05:02 PM   #9
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
but,
It works. It's the exact same as the actual Zapfilter but uses better transistors, so I consider it an improvement.
Old 29th January 2009, 08:02 PM   #10
Hello
I this Thread is very good and interesting learning
I have taken this shuntreg from an old zapfilter (Lcaudio) I know it´s sound very very good, using it in my modified cdplayer.
It gives constant 10V out.
The Shuntreg is supplied like this:
Transformer-> Rectifiers-> serie resistors to set the current flow-> shuntreg -> load
Trans BCP51 take 100mA by it self (sinks)
Can some off you simulate this??
Eks: 15V DC supply, Current to circuits 150mA (100mA BCP51 and 50mA pulled by load.
Kim
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
Page generated in 0.09596 seconds (83.89% PHP - 16.11% MySQL) with 11 queries
