Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th August 2004, 04:45 PM   #11
hjelm is offline hjelm  Sweden
hjelm's Avatar
(although 2 way selector in me pot in a box so maybe same thing)
Yes if you switch that one to another source it could make a noise, could be ok but sometimes you forget to lower the volume and get a suprise.
It is not the voltage that decides if a 1uf cap is enough, not too unusual that they are rated some hundred volts so that way it is fine.
If the amp has a too low input impedance though then it might be a problem with bas reproduction but since the manufacturer has placed it there it should be sufficient.
Hjelm
Old 8th August 2004, 07:48 AM   #12
Stones is offline Stones  United States
Stones's Avatar
Originally posted by Smiffy
Haven't got the bits yet,specs look better than 1716 but i think i may be pushing my luck a bit on the soldering skills.should be able to put them on,its getting the old 1716s off thats worrying me.seems a bit more complicated than swapping the 5532s for AD8620s was.
Smiffy
Smiffy,
Send me a pm and I will try to assist you.
Old 10th August 2004, 07:00 PM   #13
Stones's Avatar
Smiffy,
I have replied to your pm and I would be happy to provide some phone support (to lazy to type), or better still if you can get here (south of Doncaster) I would be happy to spare you a beer and a go with various professional smt rework toys.
You may find the following finds useful.
http://www.diyaudio.com/wiki/index.p...ntDeviceRework
http://www.usbmicro.com/odn/documents/46.html
Or if you are interested in investment (it will be necessary in time) search the common online auctions for example “rework”.
Capacitors for PCM1716 DAC chip Oystein Digital Line Level 1 2nd July 2009 08:01 PM
Problems with PCM1716 blu_line Digital Source 0 30th June 2006 10:18 AM
decoupling PCM1716 Smiffy Digital Source 6 6th February 2004 01:24 PM
PCM1716, is it any good? mcai7et2 Digital Source 4 17th December 2003 04:36 PM
PCM1716 in differential mode wmincy Digital Source 3 28th September 2003 07:55 AM
Page generated in 0.07909 seconds (70.62% PHP - 29.38% MySQL) with 10 queries
