Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DF1704 pin out question
Old 28th January 2008, 03:22 PM   #1
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Default DF1704 pin out question
I'm looking at a DAC that uses the DF1704 and I'm having trouble finding pin 1. I know the large recessed dot should mark pin 1, but if this is the case on this design, then the pin opposite pin 1 (pin 28) should be LRCIN and this seems to not be connected to anything. I'm not sure how this would be possible, as none of the applications in the manual for this chip show it being operated in this fashion. The only thing I can guess is that pin 1 is somewhere else... sorry for the basic question, but I'm not really sure what's going on here. Package is SSOP-28 and it is marked Burr-Brown (not TI).
Old 28th January 2008, 04:22 PM   #2
rfbrw is offline rfbrw
Default Re: DF1704 pin out question
Then it wouldn't be pin 1. How many layers does the board have ? Is there a via under the chip ? A blind via would not be visible on the other side of the board.
More to the point, if the dac actually works, LRCIN must be connected.
Old 28th January 2008, 04:55 PM   #3
luvdunhill's Avatar
Default Re: Re: DF1704 pin out question
thank you. I didn't even know these things existed I suppose it's a multilayer board. Thanks for confirming the pin 1 location. Pin 1 goes to a Xylinx chip, I was hoping that it came from the transport. The transport is a CD/DVD OEM from Matsushita, but I cannot find any model information on the drive that gets any hits on Google.
Looking at the DF1704 datasheet, I was hoping that the Xylinx chip was simply responsible for setting a few of the parameters for the DF1704 chip (this arrangement is given a few times) and that the i2s data would not pass through this chip. This must not be the case.
I'll see what else I can find out on my own
Old 29th January 2008, 01:25 AM   #4
luvdunhill's Avatar
rfbrw and others:
I finally found all three pins by backtracking from the DF1704. They go to a Xilinx XC9536 CPLD. Pin 1 of the DF1704 (DIN serial data input) goes to pin 37 of the CPLD (I/O) and pin 2 of the DF1704 (BCKIN) goes to pin 36 of the CPLD (GTS1 / I/O, some sort of buffer delay perhaps?) and pin 28 (LRCIN) goes to pin 38 of the CPLD (I/O). So, I'm assuming the CPLD takes the data from the transport and probably transforms it in some fashion to prepare it for the DF1704. I'm 99% sure this format is Philips i2s. So, my question is, can I take the output from these locations on the CPLD and pass it to my DAC? I'm not sure how things in the digial realm work, but I'm essentially asking if I can "split" these signals like this and send them to both my new DAC project and the existing onboard DAC (I cannot really "unhook" the existing DAC, so that's why I'm asking as well.. it might also be nice to compare the two).
Thanks so much!
Old 31st January 2008, 03:02 PM   #5
luvdunhill's Avatar
anyone ?
Thanks in advance!
Old 31st January 2008, 05:09 PM   #6
If the DF1704 is in hardware mode, i.e. pin 10 low, the level on pin 3 defines the input data format. It is high for I2S.
As for tapping the signal, it would be best to play safe and buffer the signals before dispatching them anywhere.
Old 31st January 2008, 06:11 PM   #7
luvdunhill's Avatar
rfbrw:
thank you. I think I will buffer using this schematic, unless you have another recommendation:
DF1704 pin out questionHide this!Advertise here!
CD-PRO2 to DF1704 GUILHERME Digital Source 21 14th February 2017 08:34 PM
DF1704 where to buy? maartentje Digital Source 1 5th February 2007 06:45 PM
CS8415A and DF1704 de-emphasis hagtech Digital Source 2 19th March 2005 10:13 PM
CS8414 to DF1704 wiring Jonnravn Digital Source 2 18th November 2004 08:01 AM
DF1704 with the Sony transport hatasa Digital Source 6 16th February 2002 04:14 PM
