| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
What will be the contact resistance of a very high quality gold or silver contact rotary switch ?
#2 |
It should be much less than 10 mOhms if it is a well made switch. The gold-flashed silver contact Elma miniature "01" series is 5 mOhms as a guide, and the NSF "JMK" series is <3 mOhms. Even a cheap (less than 1 Euro) Lorlin "CK" series with brass/silver-plated contacts claims <10 mOhms. All these examples are 'initially', so they probably do detereorate with use as a Grayhill version suggests 20 mOhm initially, with a max. of 50 mOhm, but I think that is a poor example of switch contacts. Regards,
Bob |
#3 |
when you have clean metal to metal contact, as intended, the figures are a few milliohms. Note that dirt and oil can affect all metals even gold. Silver Oxide is a conductor (good) but silver sulphide (from atmospheric contamination) is an insulator. Gold is preferred for small signals, low power, silver when there is some current being switched.
Ted |
#4 | |
thanks
I need to switch currents up to 8 mA to ground through resistors that have values as low as 30 milliohms. For I/V conversion. |
#5 | |
regards Andrew T. |
#6 | |
![]() What kind of resistors will you be using which are merely 30 mOhms in value? Regards,
Bob |
#7 | |
what's the rest of the proverb?
regards Andrew T. |
#8 | |
Higher values will be manganin wire. My idea is to integrate a volume control into the passive I/V conversion and connect the power amp directly to the low impedance passive output stage. The whole analog section is already completely free of active devices and standard resistors. I have rotary switches with 26 steps that gives 0dB to -60dB in 2,5dB steps + muting. 0,03 ohm is -60dB. 30 ohm is 0 dB |
#9 |
That's an interesting concept, and I hope that it goes well for you. If you are not already aware of it, it would be worthwhile trying some Cramolin-based contact cleaner/enhancer, in my experience. The most 'popular' being made by Caig Labs (www.caig.com) in the USA, and you will see from their website that this product is used by manufacturers in critical locations like aero-space, & telecoms etc. Their marketing names have changed over the years (Cramolin, Pro-Gold etc.), but the basic ingredient has remained the same for the 25+ years I have been using Caig products. Several high-end audio manufacturers also use it to provide lower-resistance and more reliable long-term contacts which will enhance the sounds. It also has some lubricating properties, which helps to prevent plated contacts from detereorating as quickly, and this might be of some help with your rather critical requirements here. Regards,
Bob |
#10 |
Why do you need extremely low contact resistance? If the resistors are connected in series (their sum making up 30 ohms), the switch contact will not affect them. It will be in series with the load, i.e. with your power amplifier that has high input impedance, I suppose. So the low contact resistance may not be very important.
8 mA x 30 ohms = 240 mV voltage at the input of your power amplifier, if I got it right. |
| Rotary Switch Redux ... | udtman | Parts | 3 | 25th March 2008 12:15 AM |
| rotary switch | woodturner-fran | Parts | 5 | 9th February 2008 09:04 AM |
| Rotary on/off switch | kestrel200 | Parts | 2 | 23rd April 2006 09:23 PM |
| ITT 30 position rotary switch | WALTER BURKHARD | Swap Meet | 3 | 21st December 2004 12:22 AM |
| Rotary switch | Freddie | Solid State | 1 | 30th August 2001 07:55 PM |
| Page generated in 0.10927 seconds (79.15% PHP - 20.85% MySQL) with 10 queries |
