Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th January 2008, 05:43 PM   #1
Sjef is offline Sjef  Netherlands
Default Remote PC
I'm looking for an apllication to control my music pc from my laptop. The music pc is either running Foobar (preferably) or J.river media jukebox.
J.river media center has tcp/ip support with wich you can view the complete playlist on another computer in the same network and stream the music to that other computer but that's not what I want. I want a solution that does the same except for one thing. I don't want to stream the music to my laptop I want the laptop take control over the music pc, view the playlist and send commands to the music pc.
I do not want to use the laptop as music player for several reasons. At first the music pc sounds much better, second I don't want a firewire cable to the fireface soundcard I'm using running trough the room, third the laptop does not have the same 500gb capacity as the music pc and I don't want to use an external drive for the same reasons as I don't want to use the laptop as music player (so much cables that I can't move the laptop around anymore)
I-tunes has a remote I-tunes wich can do excactly what I want, see http://www.delicioussuite.com/techno...te_itunes.html
but there are two problems with this solution, one is that it's mac only at the moment and two, I really do not like I-tunes, so I'm looking for a same kind of solution for the pc to control foobar or J.river. I have searched a lot around the web but can't find anything so far wich I find pretty strange these days where many people have media pc's in their home wich need to be controlled in some kind of convienient way.
Anybody any idea about a solution ?
Old 11th January 2008, 05:52 PM   #2
kuroguy is offline kuroguy  United States
kuroguy's Avatar
check out http://moc.daper.net and www.jinzora.com.
Old 11th January 2008, 07:47 PM   #3
If they are XP (both laptop and music PC) do some research on XP's built in remote destktop connection. Pretty much do what you want....control the music PC from your laptop.
or VNC or pcAnywhere are other remote pc control options
Old 11th January 2008, 07:59 PM   #4
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
To run MS Remote desktop, the PC that is to be remotely controlled has to have XP Pro, the remote computer can have XP home though. In the properties of remote desktop connection we can chose where sound should be played (remote or local), see pic.
/ Anders
Old 11th January 2008, 09:58 PM   #5
How about the Foobar http writer plugin that you can access from a web browser? It's not so pretty and doesn't have playlist support or anything, but it's got the basics.
There's also a TCP/IP control server that will do a lot more, but requires a telnet interface.
Or switch to Linux on the music machine and run mpd
Old 11th January 2008, 10:16 PM   #6
I have used remote desktop, vnc, radmin server in the past but the problem is that they all are very very slow because it sends out graphic data over the network, when I reduce the graphic data the playlist becomes almost unreadable. With a remote playlist there is no need for any graphic data because the remote pc has it's own rendering engine so it can be at least as fast as webbrowsing without any hickups or unreadable lines on the screen
Old 11th January 2008, 10:21 PM   #7
Also, this thread seems to indicate that a NetRemote plugin might be available that could do pretty much exactly what you want.
Old 11th January 2008, 11:43 PM   #8
DougL is offline DougL  United States
I realize its not what you requested, but have you considered softsqueeze?
Softsqueeze
This would allow you to web into your server using anything that supports a browser. Very useful if you are running PC and MAC and Linux.
You may or may not like the interface.
FWIW,
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
IR Remote Protocols - Other Remote Info PB2 Everything Else 17 7th June 2010 10:25 AM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 09:22 AM
Remote volume - existing remote Stuey Chip Amps 16 26th August 2006 12:44 AM
Remote remote volume simon dart Parts 3 7th November 2004 11:00 PM
Page generated in 0.11778 seconds (74.82% PHP - 25.18% MySQL) with 11 queries
