Ultracurve, what can I do ? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd February 2003, 02:17 PM   #1
Bernhard's Avatar
Default Ultracurve, what can I do ?
a picture first:
this is my old 8000 Ultracurve. I have AES/EBU installed and feed it with spdif.
On the output one hot pin is connected to ground to make it asymmetric.
My questions:
I can not see any OPs, where are they ?
These 14pinICs labeld "Behringer" ?
For shure there are lots of magnetic resistors and cheap caps in the signal path, especially the SMD resistors would be difficult to change, so:
Is there any DIY DAC that can be used with the AES output ?
If I use an external dac, is there any reason to upgrade to 8024, sonically ?
Any rumors about a new model coming ???
Could I built some HQ output circuit direct to the pins of that DAC ?
Thanks, Bernhard
Old 23rd February 2003, 05:46 PM   #2
The opamps are the vertical in line units marked 4580.
In my opinion you should ait for the 24/96 replacement. The 8024 is very cheap and very cheerful and despite claims in this forum requires major surgery to make it sound reasonable.
Problem seems to be in the transformer, dc power supply, clock and many cheap electrolytics. If you have lots of time and patience, may be you can improve it. It will be a major undertaking to change the opamps.
The measured performance of the unit with analog in is not good - from memory thd+n was about -70dB on the 8024.
Old 23rd February 2003, 06:55 PM   #3
Bernhard's Avatar
Wait for 24/96 replacement ? Will they bring out a better one soon ?
Old 23rd February 2003, 09:14 PM   #4
Bernhard's Avatar
Ok, this 4558 is the output stage, but where is it made symmetrical again ?
How about that ?:
Pull out the whole output stage, swap the OP for a socket, desolder all resistors and caps of the filter network, and then put bridges where necessary, so that I have the l+, l-, r+, r- on the socket.
Build a board with a new output stage and plug it into the socket.
Ground comes from the PSU.
Old 24th February 2003, 08:08 AM   #5
How about that ?:
You will have to create an input board; an output board and connect this to the software switches.
Do you have all this time and is it worth it?
The opamps on the 8024 are 4580, not 4558 which is an improved 741.
Old 24th February 2003, 09:27 AM   #6
Bernhard's Avatar
Only an output board because input is spdif.
Why software switch if only new output stage ?
My UC is the old 8000 and there is only one piece of a 4558.
Look at the photo, and three 14-pin-I-dont-know-what-behringers.
Maybe the best would be an external DAC, any recomandations ?
Behringer DEQ24/94 UltraCurve Pro $200 Zero Cool Swap Meet 1 20th March 2007 12:09 AM
FS:UltraCurve Pro +mike+cables buzzinghive Swap Meet 10 21st February 2006 11:21 PM
FS: Behringer DEQ2496 UltraCurve Pro Rescue Toaster Swap Meet 3 4th February 2006 02:38 AM
Do I need an ultracurve 2496 EQ Tuur Digital Source 1 9th November 2004 04:46 PM
Behringer UltraCurve Pro DEQ 24/96 Intelonetwo Swap Meet 5 7th October 2003 07:21 AM
Copyright 1999-2017 diyAudio
