A decent voltage regulator is part of Elso's schematic.
Adding a small separate transformer, rectifier and filtering caps instead of using your CD player's internal power supply would be the superior solution.
Connect the separate power supply's ground to your CD players ground near the clock input and make sure you never run the CD player without the clock signal.
You could also try supplying the clock circuit from batteries, but opinions about this concept differ.
