| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
http://johnson-amp.com/jstation.htm
has a choice of eg 24 amp "emulations" etc, including Marshall, Vox etc! For $140 on a switchable basis, say a tape loop, maybe would be fun (depends on the subtlety and controllability or otherwise). (Line 6, Behringer etc also do them) In a home sytem, it might do least signal degradation routing digital out from CD into such a beast, doing its DSP, then going into a DAC. You would probably only do it on mediocre quality rock recordings, but that's many of them. What do you think? |
#2 |
he did a series of experiments for audio magazine writers in which, viewing the amp or preamp as a black-box, he emulated the sound of several highly expensive devices with much less expensive modifications of Hafler amps.
#3 |
Filtering on a computer is the way with greatest flexibility.
The Johnson ‘J Station’ I mentioned is intended to run off a PC sound card in a home recoding studio. It doesn’t accept digital in, but it’s only $140, and I’m sure something else would eg from Line 6 or Behringer. Behringer is perhaps the price leader. The field of DSPs is continually expanding, and DACs and ADCs are a lot better for less $ than a few years ago. Not the commercial products, but the evaluation boards. Audiophile digital crossovers are (I think) pretty new – one was developed (last year?) for the Linkwitz Phoenix. Digital crossovers could be used in conjunction with DSPs. Anyone know of other recent digital crossover developments? |
#4 |
I am developing a loudspeaker system with DSP based crossovers for a senior electrical engineering project this semester. Should have results by end of May
![]() Mark |
#5 |
Meridian have had digital x-overs for at least the last 10 years. The first digital room correction system I can remember appeared around 10 years ago as well.
ray. |
#6 |
When I said "Audiophile digital crossovers are (I think) pretty new" I should have said in the diy realm, rather than in big bucks (Meridian) league.
Anyone built one successfully? TIA |
#7 |
A much better choice than the aforementioned J station, would be the Boss VF-1 (by Roland).
It does 20 emulations, and includes a 10 band EQ, with some parametric options. 24 bit in & out. 30 bit internally. |
#8 |
to mark: I hope you will put your project on http://www.hayenga.com/mark/
![]() to rick57: Here is some links http://www.geocities.com/john_wr2000/links.htm but it seems that there are no practical realisations. The only one crossower (working) is in LSPpro software ($500) and as another option I am waiting for Behringer dcx 2496 ($400). |
#9 |
There's also the dbx driverack PA:
http://www.driverack.com/PA.htm c. $Us 500 I'm told it sound better than the behringer DCX 2496 Thanks. I'll check those links |
| Rock - Progressive Rock ->>> | Rixsta | Music | 76 | 29th December 2011 11:03 PM |
| Of Remasters and Classic Rock... | cjv998 | Music | 46 | 9th September 2007 07:45 PM |
| Some well recorded classic rock tunes | elizard | Music | 12 | 6th November 2004 07:29 AM |
| schematic for audio research classic 120 amps? | audiomatic | Tubes / Valves | 5 | 3rd May 2004 04:25 PM |
| Need help with 2 classic rock songs | Hybrid fourdoor | Music | 2 | 26th December 2003 08:58 AM |
| Page generated in 0.10902 seconds (78.37% PHP - 21.63% MySQL) with 10 queries |
