Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st December 2007, 10:21 AM   #1
Radian is offline Radian  Germany
Default Layout question for AK4396 Dac
This is a cross post, as I asked this question at the other place, but they are a bit reserved at the moment and I need to send in my layout, to get my boards when I am on vacation.
In the attached pic with the schematic the Dac has two pins (17 and 18) right next to each other that are suppose to be tied to the 5V supply.
Each of them seems to need a separate 0.1uf decoupling cap.
Why is it necessary to do that since they are just 2mm apart?
Do I get by with just one cap like on my layout in the pic?
If someone sees any other flaw in the layout, please feel free to command on it.
Greets,
Klaus
Old 23rd December 2007, 10:10 AM   #2
SunRa is offline SunRa  Romania
Hello,
I can\t really comment on the pcb design, I don't have the experience.
What is the digital source for this DAC? From where do you get the I2S signal?
Old 23rd December 2007, 05:37 PM   #3
The I2S comes from a USB Audio device PCM2707.
Old 24th December 2007, 07:58 AM   #4
Since it's in the datasheet schematic, put in the caps. I'm guessing that the sigma-delta portion of this DAC creates a decent amount of noise, hence the need for additional filtering.
Old 25th December 2007, 11:20 AM   #5
Also, you don't appear to be using a ground plane. You need a low inductance ground. I suggest SMD parts for the smaller caps, to reduce the inductance of the high-frequency bypass paths.
AK4396 miracle dac xaudiox Vendor's Bazaar 41 27th January 2010 07:38 PM
Any DAC DIY Deisgn with AK4396? xenu Digital Line Level 0 4th April 2009 07:18 AM
AK4396 - latest DAC rmihai Digital Source 10 8th October 2008 03:53 PM
Building a DAC around AK4396 chip patherb Digital Source 1 13th June 2007 05:57 PM
AK4396 - direct-out option. beppe61 Digital Source 0 26th September 2005 11:29 AM
Page generated in 0.07864 seconds (73.89% PHP - 26.11% MySQL) with 11 queries
