Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th February 2003, 05:52 PM   #1
Audiofanatic's Avatar
Smile CD723/753 tweaking!
Hi Audio tweakers,
gpapag and I (AF), want to start a new thread about tweaking the PHILIPS CD-723/753 CD-Player's.
I'll try to dig-up the schematic within a few days and hope that I'll be able to buy a scanner in this weekend so we all will know what we can do, and how we can do the modifications to this great and cheap CD-Player.
Best Regards,
Audiofanatic!
Be nice to animals.
Old 20th February 2003, 06:46 PM   #2
Asen is offline Asen  Bulgaria
Send a message via MSN to Asen
OK
I have some experience with CD721. Brand new it sounded like twice more expensive. After some tweaks - I don't know but... like a pretty expensive CD player.
My system:
CD721
JLH 10W SE Amp
Odin - SEAS Excel speakers
vdHul cabling - D102 Hybrid interconect and CS122 speaker cable.
After all I still think the weakest points in my system are the CD player and the amp (it should be a bit more powerful even though I don't listen to music as loud as it could deliver).
Old 20th February 2003, 09:41 PM   #3
Wombat is offline Wombat  Germany
Wombat's Avatar
Here are already some ideas of modding it, that may give you some ideas.
http://www.decdun.fsnet.co.uk/projec...html#cddigiout
I have a 753 myself and only use it as transport.
If time permits - stuff some parsley in your ears and listen how it grows!
Old 20th February 2003, 09:46 PM   #4
Wombat's Avatar
Just wanted to show you how cheap you can get one with some luck.
http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=3309370360
And no, that wasn´t me i had to pay 43Euro...
Old 22nd February 2003, 05:52 PM   #5
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally posted by Wombat
"Here are already some ideas of modding it, that may give you some ideas.
http://www.decdun.fsnet.co.uk/proje....html#cddigiout"
Dear Wombat
Your help is greatly appreciated
George
Old 22nd February 2003, 08:46 PM   #6
Quote from this link - http://www.decdun.fsnet.co.uk/project.cd2.html :
Replace the three 100 ohm resistors (3502, 3503 and 3504) with 22 ohm values. This reduces the jitter on the signal going to the DAC and also improves the wave shape.
In my CD player CD721 these three resistors are 220 ohm. Can I reduce the values without harm? To what value? The DAC they lead to is TDA1545.
Old 22nd February 2003, 09:10 PM   #7
Send a message via MSN to Tazzy
I've got a 624 connected to a Cambridge dacmagic 2 and I'm also very interested in improvements
Old 24th February 2003, 11:38 AM   #8
peterr is offline peterr  Netherlands
peterr's Avatar
this site is from DIY Audio member Nuuk So he might be able to give some more tips.
Btw I just bought one as well. €50,- almost new. So I am very interested in this thread suddenly
Keep an open mind. It helps.
Peter
Old 24th February 2003, 01:05 PM   #9
massimo is offline massimo  Italy
If somebody is going to perform the mods detailed in http://www.decdun.fsnet.co.uk/project.cd2.html
pls note that in the "Modifying the CD transport PCB" section there's a mistake and should be read "remove C2890 and R3897, then short R3896".
Otherwise you totally isolate the S/PDIF output of the Signal Processor IC.
Secondly, even if not mentioned in the "Modifying the audio output section", caps 2513 and 2514 (470 pF) in parallel with the outputs are to be removed if you add 820 pF + 470 uH to form an RLC filter.
Last but not least, check the value of resistors 3537 and 3538 (RC filter with caps 2521 and 2522 in the PS of the dual opamp). They should be BOTH 220 ohm. In many units, one of this resistor is 1.2 k.
The very similar band code: red-red-brown (220) vs. brown-red-red (1200) can explain this silly mistake in production.
Old 24th February 2003, 01:10 PM   #10
peterr's Avatar
would something like this be an option? cd enhancer
Peter
A new clock mod for cd723 apolon34 Digital Source 2 27th November 2004 11:17 PM
Philips CD723 secanbj Digital Source 2 9th March 2004 11:11 AM
Anyone tried battery operation on CD723 ? Heiko Digital Source 0 2nd December 2003 02:36 PM
Page generated in 0.11052 seconds (80.56% PHP - 19.44% MySQL) with 11 queries
