Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD723/753 tweaking!
CD723/753 tweaking!
Old 6th August 2006, 04:17 AM   #111
weng is offline weng  Philippines
Send a message via Yahoo to weng
i can't find the screw maybe u can point me out where it is.
thanks
noob on the block
Old 6th August 2006, 08:17 AM   #112
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Hmmmm. It's a different transport!
This is the one in the CD723.
The yellow line points to one of the screws that fixes it to the chassis. There is another one on the opposite side.
There must be something similar holding your transport in position!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th August 2006, 09:27 AM   #113
nuuk,
can't view ur pic. pls repost
thanks
noob on the block
Old 8th August 2006, 03:26 PM   #114
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Default RE: "no disc"
Hi Weng,
THe 721 is using CDM12.1 laser assembly and the 723 sports the VAM1202 laser.I hear the 1202 laser module can also be used for cdm12.1.It's most likely that the laser has died.Try replacing it.
Old 8th August 2006, 04:17 PM   #115
Nuuk's Avatar
Weng, did you see the picture yet? There was a problem with my ISP and the picture didn't appear for a few hours.
Old 8th August 2006, 05:01 PM   #116
singa,
thanks for the info.
nuuk,
saw the pic already. it seems that the lens of my transport doesn't emit any light. the lens must be dead or something
noob on the block
Old 26th May 2008, 03:35 PM   #117
chatziva is offline chatziva  Greece
chatziva's Avatar
Hi All,
I am going to ask a basic newbies question !!
I am new to the world of DAC's. I have a CD723 which I want to use as a transport for my DAC. The DAC i have is the OPUS from Twisted Pear Audio. What I'm struggling with for a while now is to find a way to interface the two
As far as i understand one option is to feed the DAC directly with I2S signal from the CD723, but I suspect that will not be easy?
Another option would be to feed the DAC with SPDIF signal (Twisted Pear Audio also do a SPDIF to I2S receiver) but is the digital output on the CD723 an SPDIF interface? (sorry i am a newbie - i don't understand whether the term "digital output" and "SPDIF" is the same)
So i guess my question in a few words is ... how exactly can i use the cd723 as a transport with my OPUS DAC?
It seems that a lot people know how to do this trivial thing but I am struggling to find any explicit guidance ( i guess I could ask Twisted Pear Audio too!
Old 26th May 2008, 03:41 PM   #118
TimA is offline TimA
The digital output on the CD723 is SPDIF.
Tim.
Old 26th May 2008, 03:54 PM   #119
rbroer is offline rbroer  Netherlands
rbroer's Avatar
The digital output on the CD723 is non-bit perfect SPDIF , which makes it a bad choice for a transport.
Rudolf Broertjes
Old 26th May 2008, 04:05 PM   #120
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
This is true, unless you "hack" the player.
Using the hacker you can select oversampling rate and data format (EJAI or IIS) and eventually fit a TDA1541A inside as I did
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
CD723/753 tweaking!Hide this!Advertise here!
A new clock mod for cd723 apolon34 Digital Source 2 27th November 2004 11:17 PM
Philips CD723 secanbj Digital Source 2 9th March 2004 11:11 AM
Anyone tried battery operation on CD723 ? Heiko Digital Source 0 2nd December 2003 02:36 PM
