Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Dac output stage ??
Dac output stage ??
Old 21st February 2003, 02:27 PM   #11
Henrik is offline Henrik  Denmark
Output can be made as simple as this:
Henrik
Old 21st February 2003, 03:52 PM   #12
Chris is offline Chris  Norway
Chris's Avatar
Default Output
Hi Henrik
The sm 5872 is what Thorstein call a "Timeslicing (or Delta Sigma) DAC" an futher he sais it; "require lowpass filtering and (if we insist on being boring and conservative) a balanced to SE converter in case of most high performance devices".
AND more:
"The two outputs (from the dac) however need to be combined into a single-ended output and then further lowpass filtering is needed as the signal is overlaid with large quantities of ultrasonic noise. This is actually much more problematic than the already problematic situation with Multibit DAC’s."
The picture you have attached is from the datasheet is the manufacturers (npc) suggestion for the needed lowpass filter And its also the same type of filter the marantz cd63 uses.
Burr Brown dacs like the PCM 1710,1716,1728 and 1732 has integrated this in the dac chip so that you can do anything about this.
Also in the datasheet you can find fig 19 output interface 1 wich is a balanced to SE config for this dac. It all explained at this website:
http://thunderstoneaudio.nav.to/
Under: Thermionic Valve Analogue Stages for Digital Audio.
So what i have realized is that you need this filter at the output of the dac and that you cannot remove it.
A friend of mine bought the zapfilter for his Marantz 63KI and to make it work he had to connect the zapfilter after the lowpass filter. He could not simply connect it to the dac ouputs like its intended.
I did not know this when i started this thread and I`m sorry for the confusion that may have caused. My inital idea was to make a simpler output with fewer components in the signal path.I realize now that it will be bit more difficult.
Old 21st February 2003, 04:10 PM   #13
Chris's Avatar
Originally posted by Henrik
My Onkyo sound much better when I take the output just after the first opamps.
Thats what I suspected too (Less parts, more sound !!??!). Do you think its possible reduce the output stage to just one opamp?
Using only what npc suggests for output?
Old 22nd February 2003, 10:07 AM   #14
Hi Chris!
At the moment I use the red Left+ as SE output as shown in the attached scematic, and this is so so much better, hard to believe. I also tried the red Left+ and Left- as balanced output, but it turnd out awaful, no soundstage, everything bumped into the center. So my answer is yes to your question.
LO and LON.
At the moment I am building the analog stage as shown in the lower scematic, which is based on Nelson Pass supersymmetry or X. I don´t think I need the lowpassfilter at the input, since the input capacitance of the mosfets will do the job. I hope that I can run this thing balanced, if not I will remove the X feedback and let it convert the LO and LON into a singleended output.
Henrik
Old 22nd February 2003, 10:08 AM   #15
Forgot the picture.
Henrik
Old 22nd February 2003, 10:55 AM   #16
Chris
Thanks for the link to the "Thermionic Valve Analogue Stages for Digital Audio", It might be helpfull to me.
Henrik
Old 24th February 2003, 04:21 AM   #17
ashok is offline ashok
ashok's Avatar
Dac output stage ??
Default Tube stage
Hi Henrik,
You must have gone to the link and seen
"Thermionic Valve Analogue Stages for Digital Audio".
The second circuit is probably what you are looking for.
The DAC will see a balanced load because of the 'balanced' filter. The tube will hardly load the filter and so the 'balance' will not be disturbed. In addition you get enough voltage to drive almost any amp.
I have used a tube and OPA2134 interchangeably after a passive filter on a DAC. The tube sounds much better , though both sound good.
If you were a tube purist you may want to implement the circuit without a solid state device. In any case let us know how your implementation worked out.
Cheers.
AM
Old 24th February 2003, 05:05 PM   #18
ashok
Yes I am goning with the second scematic.
I got the missing information on how to deal with this modification from Thorsten Loesch´s article "Thermionic Valve Analogue Stages for Digital Audio".
The good thing about his design, besides from the tube, is that he uses the inductors, wich only reduces the voltage level very little, so one only need a follower.
I have red the recommended filtering from the datasheed of the SM5864 (which is close to te one in my CD) without inductors, but the cost is you miss half the output voltage swing, but I will play a little with this idea, and see what happens, I have attached the test scematic.
And I will be back with some comments on the test.
Henrik
Old 26th February 2003, 01:17 AM   #19
ashok's Avatar
Dac output stage ??
Default Inductors
Hi Henrik,
Did you consider using small value inductors ( 1mH and less) in the passive filter? You will get steeper roll off than RC filters. The inductors are freely available in small values and look like fat 1/4 watt resistors. I have used some successfully.
Cheers.
AM
Old 26th February 2003, 06:08 AM   #20
Ashok
I will try some variations between the one posted just before and this one to hear the difference with and without the inductor:
Henrik
Dac output stage ??Hide this!Advertise here!
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
