Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th February 2003, 04:03 AM   #1
Send a message via AIM to shallenn
Default fiber vs analogue
i wasnt really shure where to ask this question. i have a yamaha htr-5150 a/v receiver,, a toshiba sd-4800 dvd/cd player,, and a pioneer m-90 pwer amp. one source (toshiba) and two amps
(the yamaha and the pioneer). i have fiber between the yamaha and the toshiba, and patch cord between the toshiba and the pioneer. im using one set of towers and just using banana plugs to switch between amolifiers. using the yamaha via fiber the sound is great, very dynamic with a wide sound stage. but when i listen to the same music through the pioneer pwer amp via patch cord it also sounds great BUT, it is not as wide of a sound stage and the dynamics are lacking, i notice the bass lacking more than the highs but that might just be me. either way dynamics are suffering. both the fiber and the patch cord are acoustic research available at best buy. also,the yamaha is rated at about 70 wpc
20-20hz and the pioneer is rated at 200 wpc 20-20hz. i figured that the pioneer m-90 being a copper clad hi-fi beast would sound better. im hoping that i can blame the reduced dynamics and sound stage can be blamed on the patch cords!! any comments???
shallenn
Old 20th February 2003, 06:31 AM   #2
Evaas is offline Evaas  Canada
Evaas's Avatar
Question hmm
you're comparing two different recievers and two different DACs and you want to pin the difference on the cables? there may be more going on there.. see this post for more comments:
http://www.diyaudio.com/forums/showt...981#post130981
Old 26th February 2003, 01:03 AM   #3
First off, I agree with Evaas in that there are too many variables.
There are different audio interface receivers in each unit (Pioneer and Yamaha). There are different preamps in each unit. There are different output amps in each unit. You also inject the quality of the DACs in the Toshiba by passing the analog to the Pioneer. Also, the Pioneer probably converts the analog input to a digital signal to go through a processor (which in stereo obviously doesn't do much processing) which then goes back through the DACs in the Pioneer. Where as you eliminate a complete conversion chain by going fiberoptic to the Yamaha.
Try comparing each receiver using the fiber. Then compare each using the analog from the Toshiba. Does your Pioneer or Yamaha have a direct analog pass through switch (bypassing the A/D -> D/A process inside the receiver)??? If so, try that as well.
From my past experiences, it doesn't surprise me that the Yamaha would sound better. If the Yamaha has a "direct" passthrough, then I would recommend trying the analog from the Toshiba into the Yamaha. This may be slightly better than the fiber into the Yamaha. Just my $0.02.
Happy Listening
Tieftoener -- You're ears can sense a movement in air that causes your eardrum to move less than 1/10th of the diameter of a Hydrogen atom! Don't abuse the one of the most amazing organs your Creator gave you!
Old 27th February 2003, 02:24 AM   #4
the yamaha is an dolby digital/dts av reciever. the pioneer is nothing more than an integrated amp with anolog inputs only. i was thinking that the pioneer m-90 being the same thing as the elite m-91 would be a better mode of amplification. this assumption being made from build quality, original retail price, and the elite lines reputation. i am not useing a preamp with the pioneer, just the "cd direct" input and adjusting volume with the pioneers volume knob. is my sound degraded in any way by not having a preamp? more input is definetly needed!! thanks ,,shallenn
Old 27th February 2003, 03:36 PM   #5
Schaef is offline Schaef  United States
The sound is being degraded by running through the op-amps and pre-amp of the player itself.
In your case what you're comparing is the DAC converter of the Yamaha and its amps to the DAC converter of the Toshiba and the Pioneer amp. If you want a closer comparison, you need to run the patch cords to the Yamaha as well. Then you'll be closer to apples to apples.
More than likely the sound degradation you're hearing is from the Toshiba player itself. It would be an even better comparison if you could bypass the digital circuits on the Yamaha (in the AD -> DA conversion inside the receiver) and THEN you'll have a fair comparison.
Old 28th February 2003, 02:54 AM   #6
makes sense shaef. i will run patch cords to the yamaha and make comparisons and let you know.
shallenn
carbon fiber used as EM shield? neutron7 Everything Else 6 19th December 2007 04:59 PM
carbon fiber earing Instruments and Amps 8 13th March 2007 05:04 AM
How do I use carbon fiber + MDF wood + glass fiber to make speaker? sonyacer Multi-Way 16 10th May 2004 03:57 PM
Page generated in 0.10147 seconds (77.45% PHP - 22.55% MySQL) with 10 queries
