Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dac problem
dac problem
Old 6th December 2007, 03:22 PM   #1
kaldirdimgell is offline kaldirdimgell  Turkey
Default dac problem
i have got proceed dsd digital audio processor
but dsd dac card dosent work front L/R .
this unit use one dac card two pcm1702. one 1702 left other 1702 right channel.
1702 input signal type
DL = (data left )
CLK = (clock)
LE
other Pcm1702
DR = (data right)
CLK = (clock)
LE
my question
can i use just one dac (for example pcm1710 . Pcm1702 is mono Pcm1710 is stereo dac using)
1710 input signal type
DIN = (data L+R)
CLK = (clock)
LE
important part how can i use same to PCM 1710 signal type
other problem how can i converted two Pcm1702 (DL+DR) input signal same to one Pcm1710 input signal for using.
sorry i can't speak in english verywell for this excuseme
Old 7th December 2007, 10:51 AM   #2
anybody help please.....
Old 7th December 2007, 03:52 PM   #3
thanks to replies guys
Old 7th December 2007, 04:11 PM   #4
QSerraTico_Tico is offline QSerraTico_Tico  Europe
QSerraTico_Tico's Avatar
I am sorry the problem is not clear to me. Could be due to poor English or lack of technical knowledge... No offence ment!. Please try to reformulate the core issue.
Old 8th December 2007, 08:13 AM   #5
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
If i understand right your Proceed dac board with separate L/R dacs does not work and you intend rebuilding it using a stereo dac, correct?
Why not just repair what you have? Have you got a scope? Can you verify the L/R splitting is working and the dacs get the expected inputs? Are you sure the board gets correct input?
Building a new board can't increase the resale value by much.
Old 8th December 2007, 09:13 AM   #6
thankyou for replies. you can see the attached my problem
Old 8th December 2007, 09:27 AM   #7
awpagan is offline awpagan  Australia
Might help
http://www.diyaudio.com/forums/showt...?postid=610790
Indecision makes the world gone round.
Maybe
Old 8th December 2007, 09:51 AM   #8
rfbrw is offline rfbrw
Originally posted by awpagan
Might help
Probably not. The OP would be better advised to fix the original board as the PCM1710 is incompatible with the DF1700.
Old 8th December 2007, 10:58 AM   #9
rfbrw
Well maybe not.
but i was referring to his posted schematic.
Maybe
Old 8th December 2007, 11:43 AM   #10
With equipment this costly I would repair restoring the original situation.
Also much better for the second hand value.
dac problemHide this!Advertise here!
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 06:34 AM
CDM 2/29 Problem HELP! Bassivus Digital Source 29 23rd December 2007 11:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 02:19 PM
p3a problem MaXiZ Solid State 17 16th July 2005 08:14 AM
Copyright ©1999-2017 diyAudio
