Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th December 2007, 06:50 PM   #11
Originally posted by rfbrw
You chaps ought to read up on HDCP.
I forgot about that. So, you would need to get a license to deal with the copy protection issues. That's a problem.
He's not hi-fi, he's my stereo.
ShinyMetal
Old 6th December 2007, 04:14 AM   #12
I heard Sony Playstation3 converts SACD to PCM inside and send PCM on HDMI, then TA-DR3200ES or upper can receive them.
does anyone has PS3? I wonder how about BD..
I already have DSD to PCM converter and SACD/DVD-A player, by http://www.dvdupgrade.ch, I hope they also hack BD or HD-DVD player
Old 6th December 2007, 04:50 AM   #13
I recently read about that news, but turned out that it only outputs downsampled/truncated stereo PCM or re-encode it to DTS over S/PDIF, not HDMI. Well, it still offers more options than before, but thinking that most SACDs are hybrid and thus have stereo PCM version of SACD contents, it is not a big deal, I am afraid.
Old 6th December 2007, 05:09 AM   #14
Hi I remember where I saw,
http://rec.mailarchive.ca/audio.pro/2007-02/1916.html
they say
"Linear PCM 7.1 Ch 192"
"The Sony STR-DA5200ES ($1200-1400) appears to be such a device"
hmmmm... expensive
Old 6th December 2007, 06:09 AM   #15
It appears that 7.1-ch LPCM means it's supported for some contents (probably DVD-A or BD/HD-DVD, or maybe even some crazy WAV), but not explicitly SACD. Unless one says explicitly that the SACD multichannel DSD contents were converted to multichannel PCM and then transmitted over HDMI, I wouldn't believe so.
I saw that menu with my PS3, and it appears to merely specify the PCM output over HDMI supported for any audio contents. It is not directly related to SACD. Moreover, '192kHz' makes it suspicious, as 88.2kHz or 176.4kHz is the right sample rate to convert DSD into. If DSD is converted to 192kHz PCM, it involves complicated and resource-consuming non-integer ratio sample rate conversion which also introduces some artifacts. So, I'd conclude that 192kHz PCM is not related to SACD.
Old 6th December 2007, 08:57 AM   #16
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
For clarification, multichannel PCM are transmitted over HDMI for DVD-A playback. For some reason, they didn't put MLP stream on HDMI, and it simplifies the system design by not putting MLP decoder on the A/V receivers and pre/pros.
Looks like you are right, but what would one extra decoder matter? In fact, HDMI simply goes for standards: anything SPDIF will do, multi PCM, and DSD (and the lossless DTS and DD standards as of 1.3). Anything else needs to be converted..
[B]I heard Sony Playstation3 converts SACD to PCM inside and send PCM on HDMI, then TA-DR3200ES or upper can receive them.
Here is all you need to know: http://www.ps3sacd.com/faq.html
[B]It appears that 7.1-ch LPCM means it's supported for some contents (probably DVD-A or BD/HD-DVD, or maybe even some crazy WAV), but not explicitly SACD. Unless one says explicitly that the SACD multichannel DSD contents were converted to multichannel PCM and then transmitted over HDMI, I wouldn't believe so.
See FAQ above, apparently the PS3 converts multichannel SACD to multichannel PCM 176/24...
Old 6th December 2007, 07:32 PM   #17
See FAQ above, apparently the PS3 converts multichannel SACD to multichannel PCM 176/24... [/B]
Thanks. There are some good information on PS3 and media formats. BTW, it doesn't clarify which HDMI version can receive 176.4kHz multichannel PCM. I know 1.3 can, but not 100% sure about 1.2, and for 1.1, I hear conflicting stories. Do you know if HDMI 1.1 can receive 192/176.4kHz multichannel PCM?
Surprised to see that SACD support is dropped from 3rd generation. The short and pale era of DVDA and SACD are phasing away.
Old 7th December 2007, 05:14 AM   #18
Although 192 kHz is not used, I doubt that the actual sample rate conversion would have been much problem for a PS3, this is exactly the kind of thing that the cell processor was designed for.
HDMI and DCX2496 weinstro Digital Line Level 0 19th March 2009 04:45 AM
Hdmi vs optical? Hayden Digital Source 3 10th June 2008 03:31 AM
Dac with HDMI input??? kimschips Digital Source 8 15th December 2007 12:38 PM
HDMI and HDCD percy Digital Source 6 19th February 2005 11:02 PM
Page generated in 0.12654 seconds (84.65% PHP - 15.35% MySQL) with 10 queries
