| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Does anyone know what the resistor values for the data in resistors to the DAC chips? I believe they are R3, R8, R11, R14, R15, R18, R21, R24 in this schematic. Do you think swapping them out would make an appreciable difference?
Schematic Thanks |
#2 |
as long as you leave the 5532 opamp on the board, it does not matter...
On a serious note: I have tried several values between 10 and 100 Ohm and hear no difference
www.dddac.de Happy listening and building |
#3 |
#4 |
Thanks. I'm actually bypassing the output stage with a Jupiter 2.2uF cap and it sounds great. I'm going to change the R35 and R36 resistors as well with Riken Ohm's. Just trying to see if there's any benefit to changing the other ones since they are inline with the signal path. So any value greater than 20ohm is okay?
#5 | |
| Resistor values | Valvomaniac | Tubes / Valves | 5 | 27th April 2007 04:50 AM |
| Resistor Values For L Pad? | kelticwizard | Multi-Way | 8 | 16th February 2006 01:41 AM |
| Resistor values | Stocker | Chip Amps | 3 | 4th May 2004 03:10 PM |
| Resistor values? | randytsuch | Chip Amps | 2 | 11th July 2003 01:08 AM |
| Page generated in 0.08508 seconds (73.19% PHP - 26.81% MySQL) with 10 queries |
