Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th November 2007, 11:42 AM   #1
Paco is offline Paco  Spain
Default Lundhal LL1572
Hi all,
I've bought a couple of those transformers and I have a doubt. Should they be used only when there are problems or they will give a sonic improvement on a non problematic SPDIF connection?
Best regards,
Paco
Old 15th February 2008, 01:54 PM   #2
mgm31 is offline mgm31  France
I've bought one yesterday and plan to use on a AES / EBU interface input with CS8414.
Take care as this transformer is designed for 110 ohms operation (AES / EBU), I don't know if this can work with SPDIF 75 omhs with a 75 omhs resistor on the secondary.
For my point of view, pulse transformer help to break ground loop and keep the differential input of the AES / EBU.
Any advice is welcome.
Old 28th February 2008, 07:02 AM   #3
I plugged it yesterday in my CS4398 DAC.
I removed the normal stuff and replace it with this transformer + 110 ohms resistor on the secondary directly connected to pins 9 and 10 of the CS8414.
Working fine, the error led of the CS8414 remains off. I can't say if the sound is improuved as I changed from spdif to aes / ebu.
Seems that can be used with spdif (75 ohms) input.
http://www.lundahl.se/pdfs/datash/1572_1573_1589.pdf
Lundhal line input transformer question... sklimek Parts 9 11th January 2011 07:43 PM
Kron 300BXLS + Lundhal LL1623/120mA grataku Swap Meet 4 7th June 2007 12:18 PM
Lundhal Transformers For Sale Gyraf ajw Swap Meet 1 9th January 2005 09:05 AM
Page generated in 0.06669 seconds (65.57% PHP - 34.43% MySQL) with 10 queries
