| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1 | |
I'm interested in replacing the diodes in the analog power supply with FRED-types, and the critical caps with superior types (BG).
For instance, Underwood lists the following in their Level-1 mod: Quote:
Several posts here mention replacing the caps and diodes PRIOR to the Switching Power Supply, but wouldn't replacing the diodes and caps AFTER the SMPS make more of an audible difference? Any advice/comments will be appreciated -chas p.s. I will post second half of schematic below |
#2 |
Attached is second half of PS schematic, showing more diodes & linear regulators for audio stages.
#3 |
Anyone out there... have DVD2900,
or modified similar? |
#4 |
SMPS's are complex and hard to work on so when I looked at my Marantz universal player I focused on better regulators and caps after the SMPS portion of the supply.
Here's a couple of my posts: DV7600 Power Supply Upgraded Regulators Regards, Dan |
#5 |
Thanks, Dan, for the insights into your Marantz mod-
Anybody else out thare modded (specifically Denon) their DVD/SACD Player's SMPS? |
#6 |
I did mod my Denon 2900 extensively (including PS mods) about four years ago or so. I am still a happy user of the player.
I did the mods in stages. Starting from the SMPS diode bridge and Caps and the IEC Inlet and the mains supply cable and the Mains fuse. Eventually ended up building an offboard PSU for the analog stage completley bypassing the SMPS for the analog output stage. I still recall that the first diode and caps mod on the SMPS had a profound impact on the lower frequencies and in the imaging , soundstaging dept. Went on to add a LC Audio Clock module and used an off board power supply for that too. Had also added a DC jack for powering the LC Audio clock from a 12v SLA. Let me know if you need to ask anything specific. Best of luck with your mods. |
#7 | |
Regards, Dan |
#8 |
Mouser part number: 583-1N4946-B. 1 amp/600 volt ,Fast/Soft recovery diode with axial leads.
Mouser part number: 583-FR205P-B: 2A/600 Volt, fast recovery diode, axial leads. are two options for you for the diodes. I used FR205. Since I live in a 230V country so cap options were limited for me If you can get hold of a Blackgate at that voltage rating and a decent price I think it would do nicely.I used a Nippon Chemi Cap with double capacitance value of the original eventually. Here is a useful link for you: http://www.soundstage.com/maxdb/maxdb200006.htm cheers! Amit |
#9 | |
Thanks, Dan |
#10 |
Amit,
In the first schematic above, please specify http://www.diyaudio.com/forums/attachment.php?postid=1361350&stamp=1196154733 which part numbers shown did you change? Thanks in advance for being specific. Happy holidays! |
| Power cord upgrades explained? | TDWesty | Parts | 26 | 23rd February 2007 06:35 PM |
| Denon 2900 clock supply hookup. | D.A.R.R.Y.L. | Digital Source | 5 | 5th January 2006 11:54 AM |
| Denon DVD 2900 mod | audiofan58 | Digital Source | 9 | 15th September 2004 08:22 AM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.12369 seconds (78.24% PHP - 21.76% MySQL) with 11 queries |
