Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th November 2007, 04:29 PM   #1
Default super e cap
hello people, i wanna do a one on one comparison.
i want to compare a polyprop cap with a super e cap of black gates
i have two non polair black gates : 4.7ùf/50v
but they are already used, so no long and short leg
how can i find out which is which ? so that i can cancel out the noise and not double it ?
and also: you can still install the super cap in two directions (one it is a super cap) but what is the best way ?
thanx a lot people
greetings
Old 25th November 2007, 04:49 PM   #2
KP11520 is offline KP11520  United States
KP11520's Avatar
See Here: http://www.diyaudio.com/forums/showt...61#post1343361
And read his other posts on the other informative thread he linked!
Good Luck!
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Old 25th November 2007, 05:01 PM   #3
thanx a lot keith,
i'm on my way to audio heaven, gotta go now
bye
well i have looked at it,
good god, that' isn't easy, i don't have an oscilloscope, so i cannot play that trick.
gonna have to think of somehting else.
Old 25th November 2007, 07:29 PM   #4
KP11520's Avatar
Also read what Jonathan wrote on the thread that Bobken gives the link for. He has a method that requires less expensive equipment and he uses with good results. Bobken also says if Jonathan said it, then it is true. Hopefully this method will work for you!
Regards//Keith
Old 25th November 2007, 07:54 PM   #5
Bassivus's Avatar
If this helps, here is the part of the text I found on another forum...
Quote:...The shorter lead (also marked NP or NONPOLAR in case of N series) is the start of foil...
Just another thought... did anyone has experience with putting polypropylenes in reverse parallel?
Old 25th November 2007, 09:18 PM   #6
mickie is offline mickie  Germany
...yes, just look that the writing "nonpolar" is in opposite direction and there you go.
The printing is very exact and therefore reliable.
Consider also a long break-in time before judging - if the caps haven't been in use lately.
reagrds,
mickie
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Nirvana super 8 and cast super 8 how do they compare to 206E? freddi Full Range 4 22nd October 2010 02:29 AM
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 44 7th October 2009 07:01 AM
FS: SUPER CD PRO KIT with SUPER SHOCKPROOF bbp Swap Meet 5 17th April 2009 05:09 AM
Page generated in 0.08816 seconds (73.87% PHP - 26.13% MySQL) with 10 queries
