diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   TDA1540 to I2S connect (http://www.diyaudio.com/forums/digital-source/111912-tda1540-i2s-connect.html)
vrpvrp 14th November 2007 01:58 PM
Hi All!
How connect TDA1540 to I2S bus? (to PCM2706)
Hetron 16th November 2007 09:35 PM
Maybe you need this:
A shifter to delay to right justify and delay the left channel.
This is designed for the PCM1704.
vrpvrp 18th November 2007 12:15 PM
Not exactly. I now what it is needed to separate LRCK to each TDA1540 (to left and right channel)...
Aronier 17th April 2012 04:18 PM
Hello,
i would like to do the same: TDA1540 in my Philips CD-104 Player connect with I2S outpu from squeezebox.
Do anybody know how to do this?
regards
lcsaszar 17th April 2012 07:32 PM
You need a glue logic between them.
Aronier 18th April 2012 08:14 AM
Ok, thank`s and which glue logic?
Do anybody has make this?
lcsaszar 18th April 2012 07:41 PM
Search for "I2S splitter".
vizion 2nd September 2016 04:51 PM
What voltages are required to power the TDA1540 ? 5v -15v and -17v ? Can you get 2vrms output ?
Thanks.
Resources saved on this page: MySQL 18.75%
